Arcade Collecting > Restorations & repair
Robotron Restoration
<< < (7/9) > >>
vwalbridge:
Lookin' good, as usual! I love the satisfaction of restoring a CP.
Good note on the bondo to keep the CPO flush. I'm taking a mental note on that.  :cheers:
opt2not:
CP is looking clean!
Not sure what you're going to do about the Start Button lighting (the original cabinets had incandescent bulbs installed that "faintly" lit the blue buttons), but old-time BYOAC member whammoed turned me onto his LED solution to brighten up the lighting on those old buttons:
http://www.nicemite.com/LightmiteLB/LightmiteLB.htm
8BitMonk:
--- Quote from: vwalbridge on December 05, 2016, 05:03:52 pm ---Lookin' good, as usual! I love the satisfaction of restoring a CP.
Thanks, yes learn from my mistakes! ;D Didn't even occur to me that the metal plates and screws would'nt be flush. :banghead:
--- Quote from: opt2not on December 05, 2016, 09:51:36 pm ---CP is looking clean!
Thanks for the suggestion. I only recently heard of nicemite, some cool stuff. I'm going to use super bright Blue LED's from Comet pinball. Haven't had a chance to add it to my Joust restoration thread yet but here's a comparison of the color difference with a normal bulb vs. a superbright red LED.
8BitMonk:
New Back Doors.
The old back doors were faded and one swollen from moisture it picked up somewhere so I decided to make new ones.
2 pieces of Birch plywood cut to size at Home Depot then notched with a router.
Inset for the lock. I only had a spade bit and was a little lazy, would've been cleaner/better with a Forstner bit.
Used the old door as a template to drill holes for the pcb, hinges, etc.
Clean the pcb with a brush and alcohol if there are really dirty areas.
Prime and roller black for the outsides.
Spray the insides black.
End result.
8BitMonk:
Nuts and Bolts
All the parts tumbled and bolts painted.
Bleach/clean cable guides.
Speaker replacement and grill touch-up
Back handle repainted
Clean up power supply and AR board, new power cord.
Navigation
Message Index
Next page
Previous page
Go to full version
