Author Topic: typex_config has stopped working  (Read 1882 times)
ShoryuKeith
  • Last login:February 19, 2026, 10:09:31 am
  • World Warrior
« on: July 14, 2016, 04:52:03 pm »
I'm trying to setup Super SFIV Arcade edition, with the Taito Type X2
Following simply austins youtube guide. whenever i try to run the typex_config.exe as administrator, it crashes immediately with 'has stopped working'
I've tried the exact same thing on my laptop, and it works fine ...for some reason on my Arcade Cabinet PC ....it keeps throwing up this error....
any ideas what it may be?
握りこぶしのマスター
ShoryuKeith
  • World Warrior
Re: typex_config has stopped working
« Reply #1 on: July 15, 2016, 12:29:53 pm »
it seems to be the IPAC2 which is making this crash...
is there a workaround for this?
*Edit*
I found a solution if anybody else ever has the same issue:-
Go into devices and printers and in the "Ultimarc IPAC 2" hardware properties i disabled one of the "USB Input Device". There are three of them listed but only one in particular will stop the crashing so you will have to do it trial and error.
« Last Edit: July 15, 2016, 03:48:27 pm by ShoryuKeith »
握りこぶしのマスター
