Author Topic: Raspberry Pi Sound issue only when playing Vertical Games  (Read 3557 times)
hypergaming
  • Last login:May 04, 2022, 09:51:07 pm
« on: May 22, 2016, 01:00:15 pm »
Hi everyone,
I recently put together this Raspberry Pi 2 Player control panel, but I'm having some audio issues. Horizontal games play perfect, but there is a sound issue only with vertical games such as Donkey Kong, Moon Cresta, etc. I tried a bunch of them already, and they all have the same sound issue.
Has anyone ever experience audio issues only when playing Vertical Games?
here is a video link, listen carefully to the noise that comes out, and like I said, is on all the vertical games, not just Donkey Kong, so its not a rom issue.
I'm using a Raspberry Pi 2 Model B - Emulation station / Retropie ( not sure which version but is not the latest one )
I appreciate your help!
  • Last login:Today at 05:25:13 pm
Re: Raspberry Pi Sound issue only when playing Vertical Games
« Reply #1 on: May 22, 2016, 04:46:25 pm »
I had audio troubles on my pi setup too. I didnt notice any difference between games though.
I read somewhere that if you buy one of those hdmi to vga converters with audio out, you can use the audio out of it, which is supposed to be a lot better.
Of course you will have to attach that to a vga monitor so Im not sure that would work for you.
You could also try a cheap usb soundcard.
