Author Topic: Makvision Monitor M3129DF-TS discoloration  (Read 2246 times)
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
« on: May 08, 2016, 09:50:33 pm »
Hello,
In my cabinet I have an MakVision monitor along with an ArcadeVGA 3000
When the screen is static, some discoloration start to appear after a couple of mins.
Like in the picture, we can see a blue circle turning into purple on the right side.
It's not burned in. If I turn off the monitor and turn it on back again, it's fine. Again, when waiting a couple of mins on a static screen, it reappears.
For normal usage, when playing mame, it's not an issue.
Could it be dangerous?
Any idea on how to avoid this?
Thank you.
Pitou!
« Last Edit: May 08, 2016, 10:02:49 pm by Pitou »
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Makvision Monitor M3129DF-TS discoloration
« Reply #1 on: May 12, 2016, 07:01:03 am »
From what I see, that is what is called "doming". It is caused by a very bright picture which is excessive beam current going through/hitting the shadow mask inside the picture tube. The shadow mask, (I Layman's terms") is a very thin piece of metal inside the picture tube with holes the size of each pixel. The electron beam goes through these and lights the appropriate red/green/blue pixels. When too bright this piece of metal gets hot and bends out of shape, then misaligning the electron beam. So in answer to your question, no not dangerous to you. Yes could be dangerous to the video output transistors of the monitor. If you want to run this screen or others such as a Mame Hockey that might have a mainly white picture, reduce the brightness and contrast.
Hope this helps.
Rick Nieman
Nieman Video Displays
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Pitou
« Reply #2 on: May 12, 2016, 08:44:11 pm »
I'll give it a try and keep you posted of the result.
Thanks very much for the help and the precise explanation. Very appreciated.
Pitou!
« Last Edit: May 12, 2016, 08:46:25 pm by Pitou »
  • Last login:January 19, 2026, 06:58:37 pm
« Reply #3 on: May 13, 2016, 01:38:52 pm »
don't forget you are looking at an old style of display... a tube monitor... not a super bright plasma display. your eyes have been sullied by modern super high definition and big bright displays. You THINK it needs to be as bright as it is.
just turn down the brightness and contrast a bit.
Pitou
« Reply #4 on: May 21, 2016, 07:52:05 am »
Applied your suggestion and it works great!
Thank you very much!
Pitou!
