Main > Raspberry Pi & Dev Board
Xin Mo Controller 2 Player Setup on Retropie 3.6 Pi 3B... No clue what to do
<< < (4/4)
Yenome:
--- Quote from: Jimd0586 on April 26, 2016, 09:38:22 am ---Just found this out if it helps:
Port0 configs are in the system as: thtthtarcadeconsole2pusbplayer.cfg while port1 is: thtthtarcadeconsole2pusbplayer.cfg.bak
Does that mean anything to anyone? What's so frustrating is that I will config the buttons for each player but upon configuring the second player, first losses its mapping. Only two or three of the six buttons works. So I reconfigure player one and player 2 then loses its mapping. I am really stumped.
I had the same issue try to map player two first then player one. I put together a test panel with two players and 8 buttons ea. played a game and it swapped player one and player two controls. reconfiged player one and it works now in snes.
Jimd0586:
Thanks Yenome. Should I put your files you attached in my boot/config file and replace the others there? I wonder why yours reads Xin-Mo...etc. and mine says thtthtarcadeconsole2...etc.
- Jim
Yenome:
yea i would try that. it is a mystery why your says something diff i got the groovy game gear edition of the xinmo not sure if that has anything to do with it or not
drdave:
Sorry if I'm going against any necro rules in here, but I am having the exact same issue and was wondering if there was any resolution to your issue?  I even tried buying a second xin mo adapter to split off P1 and P2, but still can't get Retropie to recognize P2 buttons.
drewjbx:
this worked for me... 2 players
Navigation
[0] Message Index
[*] Previous page
Go to full version
