Author Topic: fzero ax - triforce or fzero gx hack  (Read 7602 times)
ant2
  • Last login:June 02, 2024, 07:05:47 am
« on: January 06, 2016, 05:09:45 am »
What is the most stable way to play this game?
Via triforce or the ax hack way? I am struggling to find the best answerm if so can someone please link me to the best procedure?  Thanks
isamu
  • Last login:February 01, 2026, 06:15:45 am
Re: fzero ax - triforce or fzero gx hack
« Reply #1 on: January 06, 2016, 08:25:22 am »
I remember playing AX through the "unlocked version" in GX, via some game shark codes a long time ago in Dolphin, and it ran perfectly from what I remember. That was over 3 years ago so I'd imagine it runs even better now. Heard the Triforce branch of Dolphin isn't that stable and doesn't run that well(?)
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #2 on: January 06, 2016, 09:25:14 am »
Why not just try both and see which works better  :dunno
MrThunderwing
  • Last login:Yesterday at 06:07:39 pm
« Reply #3 on: January 06, 2016, 01:59:50 pm »
F-Zero AX (as in the proper arcade version) isn't playable in any of the special Triforce builds of Dolphin, although it is possible using Gecko codes to access the and get as far as getting a game started, but once you do none of the controls work. The only way to run the proper arcade ISO of F-Zero AX is using a softmodded Wii with special Triforce running software called Quadforce. The only way to play F-Zero AX via emulation is with the regular version of Dolphin and using Gecko codes to unlock the near . It's more-or-less the same as the true version of AX, but there are a few subtle differences, such as the music used in the attract mode.
There was a previous BYOAC thread that went into a bit more detail about this.
ant2
« Reply #4 on: January 07, 2016, 05:54:15 am »
thanks thunderwing.
just spent the last hour trying to get this working with no luck.
ive got the pal version: GFZP01
I go in to: Dolphin -> right click fzero gx -> properties > gecko codes -> edit config
Now mine is blank, if I click "download codes wiird databases" it downloads some other codes.
I have tried adding all of the pal codes listed on https://tcrf.net/F-Zero_GX/F-Zero_AX_Code_Archive as well as some of the NTSC ones.
I have tried adding them to my default empty GFZP01.ini file, as well as appending appending them at the bottom of the others downloaded via "download codes wiird database", restarting dolphin and still no good.
I looked at another video on youtube and that guy had a lot of different text in his gecko codes file, stuff stating action replay, which perhaps i am missing.
I am using Dolphin 4.0-8560
Could you upload your whole file, so i can give that a go, or let me know exactly what build you are running? thanks
So this is how it looks with the version7 PAL code:
[Gecko]
$AX mode
NYJG-D3FC-ZA8BA
3DG0-ZCCM-AMTUZ
4UFX-1RHD-9D7MJ
TZRU-MK61-DCB85
G26K-1X6F-NRWAQ
74AM-V8BJ-PAZ4P
9W7G-NB19-5VVZ4
3K8T-T8PU-QZEBF
ZCJW-56Y0-WP5TE
CWC3-EJMF-U7K07
H2J7-UDWJ-7U6TA
ZRAF-EEWT-QHF64
Z2MB-C50R-1E7VY
7C19-5B3Q-W36UT
GZ19-FYXB-Y4755
WC73-XZH9-R9YJE
Y95B-QBMP-AGM1W
4A2X-5X1Q-0R954
KYGC-UHF1-81GH7
BEXK-8VHU-J6EM6
NTYZ-N9DX-CTB73
QA61-Y4JV-FYFRQ
MFBF-GNQ2-RMY99
9UYZ-PGXG-VFM0D
28VX-EC0M-QBJQR
FNXT-MUBU-49QDK
V6R0-0ANQ-UETYV
2JDZ-RAUK-4NZ2N
FKW0-7TVF-WDFZP
PQR8-YZ0C-JUGVP
DMEP-YRD9-GV8QH
UVVH-2HN6-CDPDV
D2MQ-6QWA-AYZ53
FNR6-5KCG-K3J2T
GEJ9-EFQN-5553C
ZRHC-F1DX-BKM5U
RA9Q-A6G7-GEQQH
MKN6-ZN95-N6R4Q
259B-U70T-NHN4J
M3BV-2GRM-NAZHG
YAC6-J9KV-YRBTU
RC1B-WWKJ-J0FRD
DQC4-GT65-JZ3VG
7A3Y-AHD3-1EUM2
NT5U-ZY00-QFDRU
2H2U-N53H-BP219
P9WA-5BA8-8B9PN
MU4Y-RATV-9RXEY
RD7E-RZU4-X5PFT
GCMB-UDYW-DU31H
5XNA-MPTG-7Z731
CMBZ-JW5Z-J51A7
9VQ2-CJCC-0C94F
QKJH-AVR5-5HP1D
KA4J-JYNJ-KC726
XZBC-YXKW-451M0
QBVZ-ZY7W-JPYNW
V2BY-DHCY-P27NB
[Gecko_Enabled]
$AX mode
ant2
« Reply #5 on: January 07, 2016, 07:55:07 am »
You need to "enable cheats", thats one thing i was missing.
Did that and then an error pops up " unknown instruction." - reading up on this it just states some codes just "dont work"
Tried running it under dolphin 4.0  stable and this just causes dolphin to crash completely.
If someone can give me the exact build they are running and config file for pal that would be great :)
MrThunderwing
« Reply #6 on: January 07, 2016, 12:09:09 pm »
I've got the AX Code working in both Dolphin 4.0 and 3.5-367. It's been about two years since I got this up and running so I can't give you any really specific advice, but I'll post a copy of the contents of my PAL F-Zero GFZP01 file. This also includes codes to unlock the Beta All Cup option and some other (awesome!) things. FYI, I didn't use any "download codes options" in Dolphin. You just go to "edit config" and copy and paste the codes in like you would with a normal text file.
[Core]
TLBHack = False
[Gecko]
$AX mode
06004000 000001BC
818D8364 280C0000
418201AC 3C6C000B
38630640 3883000C
38A0000C 4BFFF525
3CAC0019 80857E44
64844001 90857E44
BBC30040 BFC5BAD0
3C6C0011 A003C662
280000A4 4082000C
380000A2 B003C662
380000C0 9803F91A
A0A3C65A 3C006000
280500AE 4082000C
3C8C002F 90042A10
28050010 40820030
3C63001E 9003C784
3C630002 3800002A
B0031848 3800002C
B003184C 38000029
B003186C 3800002B
B0031870 280500AD
40820050 3C8C002F
3C003C60 60008000
9004BA38 3C003863
60003F1E 9004BA3C
3C003806 60000001
9004BA48 3C007000
6000FFFE 9004BA50
3C0080ED 60008B1C
90049658 3C00809F
600032C0 900401C4
280500B1 40820010
3C8C0030 800499F8
900D8B1C 3C8C000C
38846B80 38640028
38A00018 4BFFF425
38000000 80640024
28030001 40820010
986C0133 80640044
9003002C 900D8338
3C6CFFF8 3C003800
6000000D 9003F958
3C808000 80043F24
28000000 4082001C
3C00000B 6000002E
90043F20 3C000039
6000001D 90043F24
3C6C0007 A0043F20
B0030E42 A0043F22
B0030E4A A0043F24
B0030E52 38003860
B0030E58 A0043F26
B0030E5A 3C6C0009
3C004E80 60000020
90037ACC 80010014
4801774C 00000000
0401B900 4BFE8700
$Access Beta All Cups [CosmoCortney]
043cd608 00000000
+$AX Mode V8
06003F30 00000288
818D8364 280C0000
41820278 3C6C000B
38630640 3883000C
38A0000C 4BFFF5F5
3CAC0019 80857E44
64844001 90857E44
BBC30040 BFC5BAD0
3C6C0011 A003C662
280000A4 4082000C
380000A2 B003C662
380000C0 9803F91A
A0A3C65A 3C006000
280500AE 4082000C
3C8C002F 90042A10
28050010 408200C8
3C63001E 9003C784
3C630002 3800002A
B0031848 3800002C
B003184C 38000029
B003186C 3800002B
B0031870 3C6C0030
3C006000 90031AA8
3C003C00 60003FA0
90031C14 3C009001
600000D0 90031C18
3C003C00 60003FCC
90031C1C 3C009001
600000D4 90031C20
3C004800 6000010C
90031C24 3C003CE0
60004323 90031C38
3C0090E1 600000C8
90031C68 3C003800
6000007F 90031D30
38003F40 B0031D36
3C009061 600000EC
90031D38 3C004BFF
6000FEEC 90031D3C
3C004BFF 6000F9E8
9003208C 280500AD
40820050 3C8C002F
3C003C60 60008000
9004BA38 3C003863
60003F1E 9004BA3C
3C003806 60000001
9004BA48 3C007000
6000FFFE 9004BA50
3C0080ED 60008B1C
90049658 3C00809F
600032C0 900401C4
280500B1 40820010
3C8C0030 800499F8
900D8B1C 2805009C
40820040 3C6C002F
38000002 98039C97
98039DCF 98039F9F
9803A12B 9803A21B
9803A8EF 3800000E
98039CD7 98039E13
98039FDF 9803A16B
9803A25F 9803A933
3C8C000C 38846B80
38640028 38A00018
4BFFF419 38000001
980C0133 38000000
900D8338 3C6CFFF8
3C003800 6000000D
9003F958 3C808000
80043F24 28000000
4082001C 3C00000B
6000002E 90043F20
3C000039 6000001D
90043F24 3C6C0007
A0043F20 B0030E42
A0043F22 B0030E4A
A0043F24 B0030E52
38003860 B0030E58
A0043F26 B0030E5A
3C6C0009 3C004E80
60000020 90037ACC
80010014 48017750
0401B900 4BFE8630
+$Master Code
04003620 3CA08000
04003624 806530C8
04003628 8085361C
0400362C 7C632214
04003630 90653618
04003634 4E800020
0401BBE8 4BFE7A38
0400361C 00243E00
$all vehicles unlocked
48000000 80003618
DE000000 80008180
12000000 0000FFFF
E2000001 80008000
48000000 80003618
DE000000 80008180
12000002 0000FFFF
E2000001 80008000
48000000 80003618
DE000000 80008180
12000004 0000FFFF
E2000001 80008000
48000000 80003618
DE000000 80008180
12000006 0000FFFF
E2000001 80008000
$infinite health
48000000 801B96EC
DE000000 80C080D0
12000148 000042C8
E0000000 80008000
$All Custom Parts Available [codejunkies]
48000000 80003618
DE000000 80008180
18000020 0000FFFF
10070002 00000000
E2000001 80008000
$Access Beta All Cup [Y.S]
48000000 80003618
DE000000 80008180
1200C36C 00000000
E2000001 80008000
Once you've done that and saved the file, you should get an option to turn on which codes you want that looks like the one below. You might need to run the game once to get the options to show up (I can't remember). You just tick which options you want to work. The 'master code' doesn't need to be activated for the hidden version of AX to run, but it does need to be ticked if you want the Beta All Cup mode to run.
« Last Edit: January 07, 2016, 12:13:15 pm by MrThunderwing »
ant2
« Reply #7 on: January 07, 2016, 03:26:24 pm »
Worked  a treat. Thanks thunderwing
MrThunderwing
« Reply #8 on: January 07, 2016, 07:05:28 pm »
Cool, glad it worked for you  :cheers:
marioxb
  • Last login:January 13, 2026, 06:44:24 pm
« Reply #9 on: February 27, 2016, 09:46:21 am »
I think the best way right now is the actual arcade ISO on Wii or Wii U via the program Nintendont. It plays perfectly, and you can even use USB controllers.
