Author Topic: Daytona USA 2 Cab Conversion  (Read 29131 times)
terminator2k2
  • Last login:February 10, 2025, 05:35:27 pm
« on: November 10, 2015, 12:42:41 pm »
Hi there , thought I would share the progress on my latest purchase, which was a empty Daytona usa 2 cab.
so far ive installed:
32 inch monitor
I-pac
Pac drive led controller
Logitech wheel pcb
L2M2 Force feedback pcb
5.1 sound System
home made VR panel
sega gears 3 switch input to 4 outputs
running from a pc running Hyperspin with the following so far:
Model 2 emulator
Model 3 emulator
Triforce Mario kart gp2
Grid Auto sport
Out run 2 sp  pc version , modified by howard
just after I got it home:
then built up:
VR panel:
rear wiring:
screen bezel fitted , just needs painting on the inside..
seat covered , but not happy with the finish really, will see in the future but will do for now I suppose...
and ive started to build a marquee , inspired by Bods home made outrun 2 marquee...it wont be any where near as good as bods , but ive a start haha...
« Last Edit: August 19, 2017, 04:28:34 pm by terminator2k2 »
terminator2k2
Re: Daytona USA 2 Cab Conversion
« Reply #1 on: November 10, 2015, 12:46:27 pm »
got some sanding done and attached the sides of the topper. This is how it looks now...
im still trying to figure out where to put the front left and right speakers..i could build them into the underneath of the top of the screen bezel or put them in the marquee...
« Last Edit: August 19, 2017, 03:19:22 pm by terminator2k2 »
terminator2k2
« Reply #2 on: November 10, 2015, 12:47:31 pm »
just a small update....I got some more work done on the topper today.
here are some pics..
« Last Edit: August 19, 2017, 03:27:48 pm by terminator2k2 »
terminator2k2
« Reply #3 on: November 10, 2015, 12:49:52 pm »
youtube videos:
« Last Edit: August 19, 2017, 05:16:52 pm by terminator2k2 »
Frank Drebin
  • Last login:January 11, 2022, 04:27:19 pm
« Reply #4 on: November 10, 2015, 01:15:28 pm »
Cool!  PC specs?
terminator2k2
« Reply #5 on: November 10, 2015, 01:46:57 pm »
Cool!  PC specs?
Its running a q9450 , 8gig ram and a gtx460 at the moment
Frank Drebin
« Reply #6 on: November 10, 2015, 02:10:06 pm »
Cool!  PC specs?
Ok, so no problems running the M2 or supermodel emulators?  I'm having a hard time with demul (naomi/atomiswave) with my i5 650
terminator2k2
« Reply #7 on: November 10, 2015, 02:18:10 pm »
No they run well, havent tried demul so cant really say , i did try  initial d but it doesnt run that good anyway.
DudeRegular
« Reply #8 on: November 11, 2015, 07:49:56 am »
Looking great man.
Andy_Bogard
  • Last login:December 01, 2016, 05:32:11 am
« Reply #9 on: November 12, 2015, 06:23:10 am »
nice!
I guess you use a model 2 dash board (daytona/ sega rally ) for the use of L2M2?
Why don't you post in the driving section ?
  • Last login:Today at 11:50:38 am
« Reply #10 on: November 12, 2015, 11:30:38 am »
Looks sweet so far.  :cheers:
Projects belong in the Project Announcements subforum so the uninitiated who don't peruse the driving cab subforum can see them.
This was part of the discussion before creating the driving cab subforum.
I haven't bothered moving the ones posted in the driving cab subforum because I figured it could use the extra content for now.
That might change in the future.
The original idea was for the build thread to be here, and then have a single pic and link in the Driving Cab projects sticky.
http://forum.arcadecontrols.com/index.php/topic,130665.0.html
« Last Edit: November 12, 2015, 11:34:01 am by BadMouth »
terminator2k2
« Reply #11 on: November 12, 2015, 03:26:21 pm »
nice!
yes model 2 dash hooked up to a L2M2 + Logitech pcb. ill post in the section aswell which BadMouth has pointed out.
terminator2k2
« Reply #12 on: November 12, 2015, 03:38:07 pm »
You tube videos
terminator2k2
« Reply #13 on: November 14, 2015, 10:57:44 am »
just a small update on the marquee:
« Last Edit: August 19, 2017, 03:44:16 pm by terminator2k2 »
« Reply #14 on: November 14, 2015, 12:00:22 pm »
Damn that looks perfect.
« Reply #15 on: November 14, 2015, 12:03:24 pm »
Have you thought about trying to squeeze the speakers in elsewhere?  The model 2 cabs had the speakers firing into a pair of horn shaped boxes that ended in a narrow slot on each side of the monitor.  You might be able to pull off something similar above or below the flatscreen.
terminator2k2
« Reply #16 on: November 14, 2015, 01:27:25 pm »
cheers  :)
im thinking of putting the speakers in the screen bezel, in the cavity between the top of the screen and the top part of the bezel. ill take the speakers out of their orinigal housing and mount them at the top of the bezel.
terminator2k2
« Reply #17 on: February 20, 2016, 05:43:38 pm »
just a small update, managed to source some sega vr buttons, courtesy of northwest off ukvac forum
! No longer available
well happy with them
« Last Edit: August 19, 2017, 03:45:58 pm by terminator2k2 »
terminator2k2
« Reply #18 on: February 20, 2016, 06:01:32 pm »
well decided to strip the control panel down to fix the broken tweeters and covers..and give it a bit of a tidy up :
just letting the paint harden before I put it all back together...
« Last Edit: August 19, 2017, 03:52:44 pm by terminator2k2 »
terminator2k2
« Reply #19 on: February 22, 2016, 06:37:06 pm »
here is the finished panel:
couldn't quite get the lighting right, it was in a brightly lit room, but the camera on my phone just didn't like it...
« Last Edit: August 19, 2017, 03:54:41 pm by terminator2k2 »
terminator2k2
« Reply #20 on: February 24, 2016, 01:58:46 pm »
just need a new vr panel sticker..
« Last Edit: August 19, 2017, 03:55:40 pm by terminator2k2 »
« Reply #21 on: February 24, 2016, 02:47:09 pm »
What are you planning on doing for that?
I should have some tracings I did of originals along with a few mock-ups in various states of completion.
They'd just be in .png format.  (they are in paint.net files currently)
Not sure how helpful they would be, but it's a useable outline anyway.
I could post them if you're interested.
If you're just going to go with a new old stock sticker, then I guess they wouldn't be of any use.
terminator2k2
« Reply #22 on: February 24, 2016, 04:16:18 pm »
thanks for the offer much appreciated...im waiting for muddymusic from ukvac forums for a repro sticker...
im in no hurry at the moment as ive still got the screen bezel to paint and finish off the marquee....I need to send off my marquee design to the printers aswell.....just need to find some time....
« Last Edit: February 24, 2016, 04:18:35 pm by terminator2k2 »
terminator2k2
« Reply #23 on: March 17, 2016, 12:11:59 pm »
My new View sticker turned up today , Cheers muddy  :cheers:
« Last Edit: August 19, 2017, 03:56:52 pm by terminator2k2 »
terminator2k2
« Reply #24 on: March 19, 2016, 01:12:11 pm »
well had some spare time today and decided to spray the screen bezel...didn't turn out as expected....the blummin acrylic cracked in several places....never had this happen before and feeling well pissed....it would of turned out nice if it wasn't for the cracks...
« Last Edit: August 19, 2017, 04:02:28 pm by terminator2k2 »
terminator2k2
« Reply #25 on: April 26, 2016, 04:46:22 pm »
Just a few pics ive taken recently....ive managed to source some sega seat  cushions which were in need of help....so I re-covered them...
im hoping to replace the lcd with an original sega monitor soon...that's if I can get 1....im after a Nanao MS-2932 if anyone has 1 stuck in a box gathering dust  :cheers:
« Last Edit: August 19, 2017, 04:10:20 pm by terminator2k2 »
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« Reply #26 on: April 28, 2016, 04:36:35 pm »
wow this thing is sick !!
terminator2k2
« Reply #27 on: May 17, 2016, 05:16:40 pm »
monitor turned up today..thanks to Sarj and martin....
had a game and half trying to get in installed on me own lol....
cant remember struggling that much when I used to deliver crt tvs many moons ago....
just got a slight wobble and a bit of what looks like interference from some where....also keeps losing sync when I go from game to hyperspin.....
« Last Edit: August 19, 2017, 04:15:09 pm by terminator2k2 »
terminator2k2
« Reply #28 on: May 18, 2016, 02:31:50 pm »
well after a couple of teething problems with the monitor , I can see light at the end of the tunnel....
ive fitted my old bezel which has a nasty crack in it at the top, due to the missus treading on it when I left it in the hall way....I think ive got 1 sorted from Vamino...just need to pick it up....
The transformer is causing a wobbly picture so need to re-locate it....I hope that's all it is.....any way a few pics from today...
« Last Edit: August 19, 2017, 04:18:28 pm by terminator2k2 »
terminator2k2
« Reply #29 on: May 20, 2016, 04:44:45 pm »
terminator2k2
« Reply #30 on: May 26, 2016, 05:20:46 pm »
Marquee almost done:
« Last Edit: August 19, 2017, 04:20:51 pm by terminator2k2 »
terminator2k2
« Reply #31 on: June 22, 2016, 04:34:16 pm »
just a couple of you tube videos....nearly there now....just need to sort the seat back with a couple of stickers and try to repair a couple of cracks
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
« Reply #32 on: June 23, 2016, 08:30:21 am »
Damn is that well done!  :notworthy: Wish I had the space for dedicated cab like these!
My only nitpick (due to my "ocd" with art and colors) is the yellow of your Vr buttons sticker... It just clash. But I know it's really hard to match colors.  Very impressive work! :cheers:
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
terminator2k2
« Reply #33 on: June 23, 2016, 11:48:56 am »
Decided to attempt the seat back repair.....
there was a chunk missing out of the top left corner , and once i removed the black paint the other side had a few cracks aswell......
so ive used some epoxy putty on both sides to cover the missing broken piece and try to give the other corner some strength and prevent it from breaking off or creating more cracks.....next is to prime the area and paint it......im only going to paint the corners as i dont want the repair to stand out too much...or else it would need the complete seat back re-painting....
« Last Edit: August 19, 2017, 04:22:48 pm by terminator2k2 »
terminator2k2
« Reply #34 on: July 09, 2016, 02:45:26 pm »
had these from muddymusic on UKVAC, just need to finish the seat back and get them stuck on....
jeremymtc
  • Last login:February 04, 2026, 02:06:27 pm
« Reply #35 on: July 09, 2016, 09:46:00 pm »
Fantastic.
terminator2k2
« Reply #36 on: July 15, 2016, 02:19:44 pm »
ok managed to fix the broken seat back at the top on both sides, but spraying it fluorscent yellow was just a pain, it stood out a mile, so decided to spray the top piece black to where the top sega sticker would be going:
« Last Edit: August 19, 2017, 04:24:22 pm by terminator2k2 »
terminator2k2
« Reply #37 on: July 15, 2016, 02:25:04 pm »
and almost forgot, the monitor bezel sticker....all thanks to MuddyMusic on ukvac....cheers mate...
« Last Edit: August 19, 2017, 04:24:52 pm by terminator2k2 »
mourix
  • Last login:February 09, 2026, 04:34:25 pm
« Reply #38 on: July 21, 2016, 01:27:53 pm »
This really is the most well done racing cab conversion I've seen in a long time. You should be proud :notworthy:
« Reply #39 on: August 13, 2017, 01:17:10 pm »
bumping this hoping you can re-upload the pictures. I started to build a sit down cab but Im thinking about just converting my Daytona USA2 instead.
I'd like to see what you did so I can maybe do the same and just make new harnessed and the like to keep it reversible.
