Author Topic: Space Duel Artwork  (Read 9333 times)
TimArcades
  • Last login:September 22, 2016, 10:12:11 pm
Space Duel Artwork
« on: July 13, 2015, 11:28:46 pm »
Hi
Does anyone have an .ai or high resolution scan for the side art on a space duel ?
Tim
- Cars and Cabinets
sellsellsell2000
  • Last login:March 05, 2026, 11:46:56 pm
  • Do what you love!
Re: Space Duel Artwork
« Reply #1 on: July 17, 2015, 02:14:34 pm »
I can see if i can trace one out.
TimArcades
« Reply #2 on: July 17, 2015, 03:44:12 pm »
Thanks man!. I've been looking for 6 months to restore the sides of my cab with new prints
- Cars and Cabinets
sellsellsell2000
  • Do what you love!
« Reply #3 on: July 18, 2015, 04:47:25 am »
WIP
JDFan
« Reply #4 on: July 18, 2015, 10:08:02 am »
There is a partially done WIP of the side art here : http://vectorzorg.free.fr/WIP/#space_duel_sideart_zorg
Unfortunately according to this post ( http://www.rotheblog.com/2008/04/classic-arcade-games/new-space-duel-sideart-progress/ ) it seems iot was being done but was put aside back in 2008 and seems it was never completed.
« Last Edit: July 18, 2015, 10:12:27 am by JDFan »
TimArcades
« Reply #5 on: July 18, 2015, 01:24:29 pm »
Thanks dudes for all the help. Unfortunately I'm not that tech savvy on the artwork. I was hoping someone would have an Ai or high res scan that I could print off and apply on the sides there currently preped and ready for application !
- Cars and Cabinets
sellsellsell2000
  • Do what you love!
« Reply #6 on: July 18, 2015, 02:45:26 pm »
Thanks! It looks like it was traced. Don't have a good High Res image to trace the rest from  :cry:
JDFan
« Reply #7 on: July 18, 2015, 05:30:47 pm »
Unfortunately according to this post ( http://www.rotheblog.com/2008/04/classic-arcade-games/new-space-duel-sideart-progress/ ) it seems it was being done but was put aside back in 2008 and seems it was never completed.
THere is a set of scans I found in the links from the article -  HERE ( http://edeveaud.free.fr/tmp/scans/ ) they are decent res but are broken into 21 pieces so getting it lined up might take a bit of time but would work for tracing guides !
TimArcades
« Reply #8 on: July 18, 2015, 11:51:28 pm »
Thanks man, I'll try putting them together but it looks like some are cut at odd angles :/
- Cars and Cabinets
JDFan
« Reply #9 on: July 18, 2015, 11:55:05 pm »
Yeah - they looked a bit off on some of them (also not sure if all of the pieces are the same scale so might take awhile to get a useable image from it - but better than most of the other available images I've found !
SlammedNiss
  • Last login:Today at 03:31:27 pm
  • Mine Drags the Ground!
« Reply #10 on: July 20, 2015, 02:00:24 am »
Here is row's 1-5. Got them lined up as much as I could if anybody gets the chance to do the last couple.
https://www.dropbox.com/s/tcesrj8y27igkfi/space_duel.pdf?dl=0
sellsellsell2000
  • Do what you love!
« Reply #11 on: July 20, 2015, 04:02:53 pm »
I wish i had a high res to work with. The restoration was done vector (AI). I was at the CAX this weekend and forgot to pick up the marquee.  :banghead:
SlammedNiss
« Reply #12 on: July 20, 2015, 06:20:34 pm »
Yea, the problem with the 21 images is that the resolution sucks on them. So even if you were able to get it pieced together, it would still prove difficult to redraw.
sellsellsell2000
  • Do what you love!
« Reply #13 on: July 20, 2015, 06:36:59 pm »
I'm retracing the one of the star ship right now from a pic i've took at CAX. :dizzy:
TimArcades
« Reply #14 on: July 20, 2015, 09:31:13 pm »
This is one of the more difficult sidearts to work with. I tried to restitch the sides together using illustrator and having the same problem of improper overlap and resolution issues. Seems like some of the scans overlap with others
- Cars and Cabinets
geeteoh
  • Last login:May 30, 2017, 09:28:59 pm
  • Connecting with the 80s
    • forum.arcadecontrols.com/index.php/topic,146453.0.html
« Reply #15 on: July 22, 2015, 06:55:31 pm »
Give this a try. I attempted to take a high res photo of the side of my Space Duel. It's an original that's in pretty good shape. Maybe you can trace it to a vector image?
http://mustangattitude.com/geeteoh/arcade/SpaceDuelSide.jpg
sellsellsell2000
  • Do what you love!
« Reply #16 on: July 23, 2015, 06:55:38 pm »
Thanks. Been busy :whap
sellsellsell2000
  • Do what you love!
« Reply #17 on: July 25, 2015, 03:25:39 am »
Slowly but surely. All vector.
sellsellsell2000
  • Do what you love!
« Reply #18 on: July 25, 2015, 02:03:12 pm »
Not sure if I need to trace the entire thing or leave it the way it is?? What do you guys think?
TimArcades
« Reply #19 on: July 27, 2015, 10:29:21 pm »
Holy ---steaming pile of meadow muffin---, that looks good dude !!
- Cars and Cabinets
sellsellsell2000
  • Do what you love!
« Reply #20 on: July 30, 2015, 02:44:29 pm »
Is getting close! :oldman
SlammedNiss
« Reply #21 on: July 30, 2015, 08:52:47 pm »
I gotta say, that's pretty damn impressive!  :applaud:
sellsellsell2000
  • Do what you love!
« Reply #22 on: July 31, 2015, 07:18:47 pm »
Space Duel up for download.
Just open up the PDF file and drag it to Adobe Illustrator and should have full access to each graphic(s). You should be able to scale to what ever size you want.
NOTE: select each item individually, hold the 'shift' key down and drag any bounding box!
Enjoy
« Last Edit: August 01, 2015, 02:52:28 pm by sellsellsell2000 »
sellsellsell2000
  • Do what you love!
« Reply #23 on: August 04, 2015, 04:02:48 am »
Space Duel Marquee done!
lamprey
« Reply #24 on: August 04, 2015, 11:47:12 am »
Enjoy
Thanks for doing this! I've been thinking about vectorizing this stuff so I can make a custom bezel and now it should be much easier!!
sellsellsell2000
  • Do what you love!
« Reply #25 on: August 04, 2015, 04:01:26 pm »
NP. Here is the marquee. The physical size is 26X9; recommended size trim is 25.5"W X 8"H
TimArcades
« Reply #26 on: August 04, 2015, 06:04:40 pm »
Thanks a million. I'm going to get this printed this week :)
- Cars and Cabinets
sellsellsell2000
  • Do what you love!
« Reply #27 on: August 04, 2015, 06:14:10 pm »
Sweet. Post some pix when you do.  :cheers:
