Author Topic: Verticade(s) 2015  (Read 10416 times)
davidgilmour
  • Last login:April 11, 2025, 09:01:44 pm
Verticade(s) 2015
« on: May 13, 2015, 02:19:10 pm »
So, after wanting a cabinet for quite some years finally decided to build one.
And since I love Arkanoid it is gonna be a vertical one, the verticade.
So I started with the plans from Koenigs.dk.
Bought the first stuff couple of weeks ago and had to wait for some stuff coming in.
I started with this
Three plates of MDF ( 2 were sufficient , but just to be sure should things go wrong ).
Then I ordered these two ( well, 2 extra too just in case should things go wrong )
Found somebody who could cnc the mdf and acryl for me , he had this:
And within one hour I ended up with this
and this:
« Last Edit: June 07, 2015, 02:12:23 pm by davidgilmour »
Superfrog
    • My YouTube Channel
Re: Verticade 2015
« Reply #1 on: May 13, 2015, 02:49:43 pm »
you made a very good start.
My first Verticade I did everything with a jigsaw  and a lot of sandpaper  :banghead:
Happy building time  :cheers:
davidgilmour
Re: Verticade 2015
« Reply #2 on: May 13, 2015, 03:40:02 pm »
Thanks, I've been inspired by the original Verticade build and your builds as well. Yours is fully mdf and I will do the mix of mdf cabinet with acryl panel. Will try to build the original one with only slight change of the back and internals will differ as well a bit.
Not sure about the colour, yellow is an eye-catcher but I might go for the greyer safer colours.
reptileink
  • An 8 bit hero
Re: Verticade 2015
« Reply #3 on: May 16, 2015, 09:47:50 am »
A mix of grey and red would be slick...
davidgilmour
Re: Verticade 2015
« Reply #4 on: May 23, 2015, 03:47:39 pm »
So I had time to pick up my project. Went out to buy some wood for the mouldings. The specs were 22mm x 22mm but my store only had 22x30 or 18x18. Found the 22x30 too big so I bought the 18x18. I'll take the risk.
Specs said 350 cm, my stick was 270cm. Should be sufficient.
So I ended up with this
And all was left over was this:
That was a good start  :lol
There are 2 mouldings missing on the first picture but they were there. This is a small test how everything should look (approximately):
Then when I tried to attach the mouldings I had my first problem. The mouldings split when I was putting a screw in them. Search the net and read a tip about putting soap on the screws, tried that but they still broke.
I had black screws, are they ok for wood? 25mm screw through a 18mm moulding. Hmm. What should I do.
I said, well "  :censored: that" , I will just glue them  :hissy:
So I glued them and even managed to glue the bottom, after the first lift it looked like this:
Everything is glued,except for the back door, that one is loose, just for stabilization.
And after glueing some more mouldings and plates this is how far we got so far:
« Last Edit: May 23, 2015, 04:01:03 pm by davidgilmour »
firedance
  • Last login:February 17, 2026, 01:36:18 pm
Re: Verticade 2015
« Reply #5 on: May 25, 2015, 02:09:10 am »
You needed to pilot drill the mouldings first, then screw in the screws :)
http://www.popularwoodworking.com/techniques/q-a-why-predrill-screw-holes-2
davidgilmour
Re: Verticade 2015
« Reply #6 on: May 25, 2015, 03:52:20 am »
Yes, beginners mistakes  :) but still, everything worked out fine. I can lift the cabinet with one hand on the top layer, so it seems to be very steady with just the glue. I will use screws for the monitor mouldings that I still need to attach, i have some 22x30 mouldings that I will glue/screw. The monitor is 5 kilograms, tha needs a good moulding  :)
davidgilmour
Re: Verticade 2015
« Reply #7 on: May 25, 2015, 01:10:50 pm »
Had some time to (almost) complete the control panel
First glue the two acryl plates together with this:
Then fill the gap between two mdf plates with polyester putty
And some primer paint, first layer
Need to fix a little bit at the back with some more putty polyester, will do this week:
« Last Edit: May 25, 2015, 01:22:32 pm by davidgilmour »
davidgilmour
Re: Verticade 2015
« Reply #8 on: May 30, 2015, 05:42:43 pm »
Second layer of primer
Then it was time to decide for the colour, chose warm yellow, just like the original verticade.
The one on the left
Unfortunately there must have been a production error at my paint store, because it was a few colors off
I found it too cold and bright, Ferrari yellow or Pacman yellow.
So I went back to the store where they don't return colors but they also found it way off so I got 50% discount on the new paint normally 17 euros for 0,5 liter, got it for 5 euros (30% extra discount for every customer)
And took another color, a bit warmer then the one I originally wanted, just to be safe (door panel is old wrong pacman color, cabinet is new warm color)
I think yellow is quite a difficult color to recreate, here is the mamecade from superfrog compared to the original verticade:
compared to the original:
« Last Edit: May 30, 2015, 06:15:30 pm by davidgilmour »
davidgilmour
Re: Verticade 2015
« Reply #9 on: May 31, 2015, 12:32:39 pm »
Current state:
davidgilmour
Re: Verticade 2015
« Reply #10 on: June 07, 2015, 01:50:33 pm »
I've been working on a side project this week because I need to wait on my power supply unit for my pc, will be here in two weeks.
When I brought my mdf plates and the verticade plans to my cnc cutter he was so impressed by the outcome that he made a 9mm mdf verticade as well. Just the mdf but one that had 'lasered' mouldings, i.e. Cut in the mdf itself (except for the cp and marquee). He gave it to me for free so I could use it as an example for my 12mm verticade.
But the build quality was so good that I thought: i will use it for a hirizontal monitor. So I put it together and got this:
Only problem is that I had to glue all together, so also the back door. I will put a horizontal monitor in it and will try to keep the costs as low as possible for this one. Will use a monitor I already have and of course i have a lot of stuff left over (glue, paint, etc) from my main project.
So I grounded it twice and want this to have another colour, so I bought some cheap 5 euro paint and this was the result:
So it is light grey. But I have a big challenge with it. I can't open the backdoor, so I will need a workaround to be able to remove the monitor should I ever need to in the future. So I came up with this.
Attached the mouldings and put some velcro on it. So I will be able to remove the monitor.
Question is: will it hold? Well, just test it  :-\
And yes, it worked  :applaud:
So all I have to do for this panel is : attach a pc with psu, a control panel, marquee en plexi cover glass.
I already bougt the PC: a intel quad core inside this Windows 8.1 PC: the Pipo X7.
« Last Edit: June 07, 2015, 02:10:29 pm by davidgilmour »
davidgilmour
Re: Verticade(s) 2015
« Reply #11 on: June 19, 2015, 02:26:03 pm »
So I have all the stuff for my original Verticade now, so I picked that one up again.
Installed motherboard, pico psu, ssd drive, speakers and all alectricity including leds.
The LEDs:
Electricity:
The speakers:
And this is the back door:
All I have to do is marquee, attach monitor and cp with front and install software. A few weeks and it is finished.
« Last Edit: June 19, 2015, 02:34:34 pm by davidgilmour »
davidgilmour
« Reply #12 on: August 08, 2015, 10:50:23 am »
Went on holiday and almost finished. Just need the marquee.
Monitor installed. And mame installed but need to fine tune the software as well. But my main goal was to play Arkanoid and that plays perfectly with the spinner. A minor scratch is visible, wil put some paint on it when I have the marquee.
« Last Edit: August 08, 2015, 10:53:41 am by davidgilmour »
Superfrog
« Reply #13 on: August 08, 2015, 02:26:54 pm »
Great result David  :applaud:
Reminds me of my first build, but you DID use the spinner.
I was a cheap bastard and skipped the spinner back then, that was a  :banghead: :banghead: :censored: :censored: decision  :laugh2:
davidgilmour
« Reply #14 on: August 15, 2015, 11:23:30 am »
And the marquee is done. This one is now finished.
« Last Edit: August 15, 2015, 11:28:19 am by davidgilmour »
stigzler
    • Mago Arcade
« Reply #15 on: August 16, 2015, 05:05:56 pm »
Clean. Simple. Like it.
davidgilmour
« Reply #16 on: August 23, 2018, 03:46:00 pm »
So I was bored with the yellow colour and updated mine.
I also installed HyperV 1.8.
mame only.
« Last Edit: August 23, 2018, 03:47:34 pm by davidgilmour »
Drnick
  • Plodding Through Life
« Reply #17 on: August 23, 2018, 04:14:30 pm »
Nice, simple machine  :cheers: What did ya do with the horizontal one?
davidgilmour
« Reply #18 on: August 23, 2018, 04:17:46 pm »
Still need to finish that one. I have an intel nuc pc inside it. Will take a few months but I will be able to show it before jan 1, 2019  :)
Drnick
« Reply #19 on: August 23, 2018, 04:24:52 pm »
That's probably before I cut any wood on my next project. I do love me my NUC, and am looking forward to the day I replace it from under my TV with something else so I can put it in my Bartop (which should take about 10kg off the weight of the thing).
