Author Topic: It this possible?  (Read 5726 times)
Wayside
  • Last login:January 24, 2016, 09:55:55 am
It this possible?
« on: February 22, 2015, 06:01:52 pm »
Using mala layout, is there a way that when a specific game is highlighted, I can have a section (like the screenshot or marquee or text info) that will display a custom text for each individual game?
I have so many random games that are fun, but without committing them all to memory, I sometimes forget what buttons do what in the game.
For example:
I highlight rampage world tour.  On the left i would like a custom text to say "button 1 = punch  button 2 = kick button 3 = jump"
Then I move one game down and its street fighter.  I want the text to change and say different text and so on, and so on.
Is this possible?
Thanks for your time
BorgDog
Re: It this possible?
« Reply #1 on: February 22, 2015, 10:51:31 pm »
I'm doing something similar by using the control panel pictures, that shows what each button on my layout does for that game as I don't have my games buttons labeled, and has the unused buttons kind of grayed out.  attached is a pic of one of them.  I don't know if you can do a text box for them, but if nothing else you could make an image of the text and use the same method I did.
« Last Edit: February 23, 2015, 09:05:34 am by BorgDog »
My Projects:
empardopo
  • Last login:November 17, 2025, 01:32:25 am
    • My personal forum
« Reply #2 on: February 23, 2015, 03:08:30 am »
I've never heard adding text but It's possible to add a pic like BorgDog told you.
Greetings.
Wayside
« Reply #3 on: February 23, 2015, 06:53:56 am »
Thats what I thought.  Thanks for that Borgdog!
bmanbdaman
  • Last login:May 09, 2018, 10:03:23 pm
« Reply #4 on: February 23, 2015, 08:11:02 pm »
You can use text based on many settings that are defined. I just updated a template with a Text Object and added this.
Pattern=B1: ~c_button1 B2: ~c_button2 B3: ~c_button3 B 4: ~c_button4
And it shows the text just fine. Also searched and found answer already given  here.
« Last Edit: February 23, 2015, 08:19:12 pm by bmanbdaman »
Wayside
« Reply #5 on: February 23, 2015, 09:55:12 pm »
ty for the tip!
empardopo
    • My personal forum
« Reply #6 on: February 24, 2015, 03:22:04 am »
But, when I select the KungFu Master game, I would like to see a text saying "My favourite game..." and when I select the Commando see the text : "I hate this game...". I think this is imposible,isn't?
bmanbdaman
« Reply #7 on: February 25, 2015, 09:47:06 pm »
There is a text option for the miscDetails section in controls.ini. You could modify that file and re-import your roms to make a new Mala gamelist or use romlister to merge it for you. Then use Pattern=~c_details for a Text Object in your template. That may work.
It could be easier to modify the history.dat and show that comment in an Info window or maybe create a Game List called Favorites.
empardopo
    • My personal forum
« Reply #8 on: February 26, 2015, 01:43:57 am »
It could be a solution. Good idea,thanks.
empardopo
    • My personal forum
« Reply #9 on: March 13, 2015, 02:59:50 am »
For example:
Is this possible?
Take a look here. It'll be available very soon...
Greetings.
