Author Topic: Volume control knob --- cp or beside speakers?  (Read 3917 times)
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
« on: January 19, 2015, 06:57:03 pm »
Hey everyone, I just purchased a Griffin Powermate to be used as my volume control knob. My question is.....does anyone have any suggestions re whether I should install in on the control panel or beside the speakers of the arcade machine.
Or anywhere else for that matter.
Thanks for any advice!
Re: Volume control knob --- cp or beside speakers?
« Reply #1 on: January 19, 2015, 06:59:13 pm »
Hidden behind the coin door.
thomas_surles
« Reply #2 on: January 19, 2015, 08:23:18 pm »
I put mine in between the speakers under my marquee.
Fast351
  • Last login:November 22, 2020, 10:49:37 am
« Reply #3 on: January 19, 2015, 08:36:50 pm »
AzureKnight
« Reply #4 on: January 20, 2015, 01:55:35 pm »
Does your CP overhang the sides of your cabinet?  I put mine coming out the side of the cabinet but hidden behind the CP.  You don't see it from the front or left side at all, but it is within very easy reach when needed.  I've only really had the thing running for a few weeks but I do find I change the volume a lot from game to game.
« Reply #5 on: January 20, 2015, 02:12:24 pm »
This!
I disagree.  There's too much variation game to game.  I adjust the volume constantly.
I'd recommend on top the cab or under the CP.
Somewhere it can't be seen, but is within reach for quick adjustments.
Might not look bad on the panel that the speakers are mounted in, depending on your cab.
« Reply #6 on: January 20, 2015, 02:22:10 pm »
This!
I have it behind the coin door so other people don't mess with it.  :cheers:
« Reply #7 on: January 20, 2015, 02:39:43 pm »
 :notworthy:
« Reply #8 on: January 20, 2015, 02:48:25 pm »
 :notworthy:
I put an external volume control on my jukebox as a nod to my wife, who wanted to be able to turn it down, but what happens is people also want to try and play "Let's Blow Out The Speakers" as well.  :cheers:
johnrt
« Reply #9 on: January 20, 2015, 02:57:49 pm »
I use The Force to control the volume.
If that doesn't work, I also have a volume knob inside the cab. (I don't have coin doors, so I just open the front- or back door).
lisowskikevin
« Reply #10 on: January 20, 2015, 08:08:06 pm »
Ya mine overhangs so I could definitely do it, I actually like the sea the more I think about it.
Thank you to everyone for their valued opinion. I am definitely going to avoid the temptation to put it on the control panel...it would be dumb to put it there in hindsight. YOU GUYS ROCK!
« Reply #11 on: January 20, 2015, 09:17:51 pm »
Pics of your cabinet may help too.  :-)
  • Last login:Yesterday at 11:02:50 pm
« Reply #12 on: January 20, 2015, 09:31:12 pm »
I find the variation in volume to be authentic but I know this forum is flush with those that never stepped foot in an arcade.
ChanceKJ
« Reply #13 on: January 21, 2015, 02:13:12 am »
What's an "arcade"?
Here's what I did with my PowerMate, it's on the fron of my control panel, out in the open and I don't think its "dumb".  :D
keilmillerjr
  • Web Developer.
« Reply #14 on: January 21, 2015, 06:13:12 am »
If you set your computer volume to max and then adjust your amplifier to the loudest you want your cab, having an os volume adjustment for the end user is no big dea and is not dumb.
« Reply #15 on: January 21, 2015, 09:39:45 am »
So the moral of the story is that everyone does it differently, so do whatever you want.  :cheers:
« Reply #16 on: January 21, 2015, 10:21:01 am »
Go take your moral relativism elsewhere.
« Reply #17 on: January 21, 2015, 11:14:22 am »
Your momma wears combat boots.
UFO
  • Last login:July 31, 2025, 01:00:25 pm
  • Im nearly out of unproductive things to do at work
« Reply #18 on: January 21, 2015, 02:46:11 pm »
+1 ... that's what I have done...
lisowskikevin
« Reply #19 on: January 21, 2015, 06:41:38 pm »
What's an "arcade"?
haha sorry Dumb may not be the right word. Your setup is very clean looking. Nicely done.
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
« Reply #20 on: January 22, 2015, 11:11:45 am »
MAME has a volume arg that makes adjusting volume for MAME games pointless.
Set your volume to be correct for the most quiet game.
For the louder games, just setup your frontend to run with something like "mame.exe sf2 -volume -12," which will run it with -12dB attenuation. Problem solved. Every game is normalized, and you never have to adjust the volume.
Problems might come up with butt sucking programs that don't let you adjust the volume, but I think almost all of them do. Most native PC games have a volume setting, and most standalone emulators do, too. It can be set up perfectly.
bulbousbeard
« Reply #21 on: January 22, 2015, 11:18:58 am »
And smelly, rude ---uvulas--- breathing down your throat while you play would be authentic, too, but it'd also be about as appealing as not having normalized sound volume. What's great about our options today is that we can get exactly what we've always wanted: all of the quality gaming with none of the STINK.
« Reply #22 on: January 22, 2015, 02:04:41 pm »
I have used a hacked pair of computer speakers, using the amp's pot in it for the volume control.
I have unsoldered the pot and placed it away from the amp, but its best if you can leave it soldered to the amp.
I have mounted the knob on the control panel once. Didnt care much for that, cant remember why.
All the others have been mounted between the two speakers below the marquee.
The knob on computer speakers is small and not that noticeable, but I can see when the knob on a powermate might stick out like a sore thumb.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #24 on: January 26, 2015, 09:07:20 am »
Note that if you are using an I-PAC board you can program any controls for volume up/down.
So you can also use the shifted controls to avoid the need for any dedicated control, for example Start1/Player 2 UP for volume up and Start1/Player 2 DOWN for volume down.
EMDB
  • Project RetroCade
« Reply #25 on: January 26, 2015, 09:19:48 am »
I use Shifted Joystick 1 up / down to control the volume...
jasonbar
  • Dr. Inferno
    • The Infernolab
« Reply #26 on: January 26, 2015, 11:58:31 am »
Don't put it next to the coin door, filling the hole left by an old bill acceptor... Unless you want your 2-year-old to mess with it...  :-\
