March 01, 2026, 11:36:32 pm
I use a pair of wireless headphones with my PC (Sennheiser HDR 170) and it definitely rocks your ears. I can't even max the volume in most games because it's so loud.Only MKII has really weak volume that I can recall right now.
what happens if you launch mame form command line instead of your front end?
so, what if you make a new folder and put just the mame exe and a rom in it and run that? This just helps pair down the possibilities.
If you're running this in Windows, click on the speaker icon, open up the mixer, and make sure you have accidentally cranked down the application volume.Here's what it looks like on mine:
So I've done plenty of searching and found similar problems, but not THIS problem... compared to the system sound of my computer, MAME is very quiet, and not just midway games. I've maxed out the master volume, i've gone into the TAB menu of the roms and maxed out all of those volume channels. I even opened the volume control and set MAME to 100% and Hyperspin to 5%, Hyperspin is STILL louder than MAME! Any suggestions?
