Author Topic: Project - Portable Arcade Ghosts 'n Goblins  (Read 11664 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« on: April 08, 2014, 10:33:08 am »
Hi
After I came to the conclusion that I have no more room for arcade machines ..
I decided to build something smaller.
I'll  will  put up a PC or disassemble a laptop. is still not decided.
2 joysticks for two players. and IPAC.
here some pics:
the plane
the mother board p4
Computer disassembled
My carpenter is a tough guy  ;)
after 3 hour....
Here I plan to put a marquee.
« Last Edit: July 12, 2014, 03:05:43 am by jackiabu »
BobA
  • What Me Worry?
Re: Project - Portable Arcade
« Reply #1 on: April 08, 2014, 11:52:56 am »
Great work in such a short time.   What type of plywood are you using?  Looks like there are a lot of layers for strength.
404
« Reply #2 on: April 08, 2014, 01:14:33 pm »
D101GCC board. I had tons of those things in a pile a few months ago. They run soft15khz and calamity drivers quite nicely.  :)
jackiabu
« Reply #3 on: April 08, 2014, 01:22:41 pm »
Thanks men. the wood is sandwich.
Unstupid
« Reply #4 on: April 08, 2014, 09:06:14 pm »
Shoulda made your top piece longer so it overlaps the back piece.
jackiabu
« Reply #5 on: April 09, 2014, 12:52:22 pm »
Update:
so its time to drill . Two joysticks and four buttons per player.
from the back i want to drill for the fun,HDMI,and the Metal rectangle that come whit the motherboard
 have two joysticks of Mag-Stik. but not sure...Their movement is not smooth :-\
Generic Eric
« Reply #6 on: April 09, 2014, 12:55:05 pm »
I don't understand where the screen goes?
BobA
  • What Me Worry?
« Reply #7 on: April 09, 2014, 01:02:11 pm »
Probably on the wall. Largescreen tv or projector.
jackiabu
« Reply #8 on: April 09, 2014, 01:07:10 pm »
it's portable, LCD,plasma,or just T.V. through vga or HDMI ;)
Generic Eric
« Reply #9 on: April 09, 2014, 02:20:34 pm »
That is a good idea.  I've had 70/30 success using an alternate input on a TV at a Hotel.  I can see how this could come in handy.
Other thought.  From the profile drawing especially, it is reminiscent of the Atari 2600.
jackiabu
« Reply #10 on: April 15, 2014, 03:28:56 am »
Well after much thought, I decided to reassemble everything and go on a shiny black formica. ::)
the side
Apart from player 1 and 2. Added up some holes for:coin,pause,tab,esc.
here is it finally...in the back i pot a vent
Yes I know these flowers look with some part of the kitchen. But the carpenter's mistake. He added that accidentally on the formica. In any case I'm going to put up a sticker so it should not bother me ...
 I added another hole, button ON / OFF
and open....
meanwhile my IPAC is here.the joystick is not for this project
Now I have left the label and design ... I have not decided yet I am debating between the Amiga logo, or ghost n Goblin :dizzy:
Unstupid
« Reply #11 on: April 15, 2014, 03:48:21 am »
Nice job with the top panel...  Looks much better now.
What are you using for the edges?  Is that edge banding?  It looks a little thin resulting in some white around the edges.
I see you put a vent fan in, but, where are you venting from?  You need an intake hole where you can draw air into the case, preferably across your motherboard.
jackiabu
« Reply #12 on: April 15, 2014, 10:21:29 am »
thanks men.
The edge is banding. I using this
about the venting. my plane is to put a motherboard. and all the hot air will came out ::)
The fan came on the back of the machine without screws.
jackiabu
« Reply #13 on: May 24, 2014, 12:02:19 pm »
I finally cleared some time, children, My mother in law >:D
I decided to design the machine in the style of Ghostn Goblin. My dilemma was between that or the AMIGA :P But in the end I decided to stay with the Ghostn Goblin.
the panel
or this...
head
top
side a
side b
the AMIGA will have to wait to my next project :-\
so that it. This week I have to go to print it.
jackiabu
« Reply #14 on: May 26, 2014, 11:47:16 am »
well go to print today here is the resolute ;D
the printer in action....
another view
danielmarokoi
  • Last login:July 30, 2015, 05:58:20 pm
Re: Project - Portable Arcade Ghosts 'n Goblins
« Reply #15 on: June 04, 2014, 01:47:53 am »
What a stunning design you did for the Ghostn Goblin. :applaud:  curious to see the end of this project. :cheers:
jmike
« Reply #16 on: June 05, 2014, 11:17:21 am »
Great job on that artwork!! GnG is one of my favorite arcade games.
Pretty sweet build you go there.  :cheers:
jackiabu
« Reply #17 on: June 06, 2014, 05:19:28 am »
thanks for the compliance guys ;D
jackiabu
« Reply #18 on: June 06, 2014, 05:33:13 am »
Trying to assemble the screws I ordered from ULTIMARC http://www.ultimarc.com/controls.html#mountingkits
I could not screw the bracket  (hex key) to the end ???
Need to dismantle them, and reassemble.
  • Last login:Yesterday at 03:02:52 pm
« Reply #19 on: June 06, 2014, 04:22:04 pm »
The wide, flat threads on those threaded inserts slice into the MDF.
They can't be removed and reiinserted without pulping the MDF. :badmood:
You only get one shot at it -- if you mess up, you'll need to re-make the whole piece.
IIRC someone (maybe rablack97?) used a machine screw and nuts in a drill press (turned by hand, of course) to keep the inserts straight vertical while inserting them.
EDIT: Found it.  Rodney posted the video below in his DIY acrylic bender thread.
NOTE: The inserts shown in the video are for normal wood, not the kind used for MDF -- totally different thread geometry, but the insertion process is the same.
« Last Edit: June 06, 2014, 04:51:14 pm by PL1 »
JDFan
« Reply #20 on: June 06, 2014, 04:33:50 pm »
Could probably redrill the hole larger to remove the blowout - fill with Bondo\wood filler\mixture of wood glue and MDF Sawdust\ or similar - let dry completely and sand then start over rather than re-making from scratch !
« Last Edit: June 06, 2014, 04:36:33 pm by JDFan »
jackiabu
« Reply #21 on: June 07, 2014, 02:56:32 am »
hanks guys for the tips  ;)
I did not know these screws are messed up. :banghead:
All the panels that  i have built  until now. I've used regular screws.
anyway i give it a try.
« Reply #22 on: June 07, 2014, 04:22:31 am »
if the threaded inserts are working, no need to re-do them -- I thought you said they weren't properly mounted and planned to dismantle  and reassemble them..
The threaded inserts are definitely a better choice than wood screws because the threaded inserts allow you to remove the machine screws holding the joystick without stripping out the MDF.
Forgot to mention that you do get a second chance with the inserts if you can turn the mounting plate/joystick 90 degrees.   ;D
Just take your time and do it right.
Regular wood screws will cause problems if you ever have to remove a joystick and they are more likely to work loose just from normal gameplay.  :(
« Last Edit: June 07, 2014, 04:35:47 am by PL1 »
zanzi
  • Newbie
  • Last login:June 08, 2014, 01:24:43 pm
« Reply #23 on: June 08, 2014, 01:24:43 pm »
i realy like the graphics. the white sides gives it a tech look. waiting to see it with controlles colors. i also really like the wood frame - it looks very strong, also think the upper panel should have been on top for larger area, but mabee it would not be so strong.
good work man - i love you enthusiasem
« Reply #24 on: June 08, 2014, 01:48:35 pm »
Nah, I've used those inserts in MDF without issue. But yes, once they're in, don't take them out.
jackiabu
« Reply #25 on: June 10, 2014, 04:48:59 pm »
Updating...
At last I managed to screw the  until the end...I hooked one joystick. Strong and steady as steel.
Meanwhile, I have another shipment arrived. Among others PCB Mounting Feet
start working on the motherborad and the hard disk
zoom in...
Now I have a little problem. I need to place the power supply.
I drilled two small holes, and I'm afraid they touch at the inside, and can shorten. :-\
Any ideas how I mounting the power supply. Without to need screw?
JDFan
« Reply #26 on: June 10, 2014, 05:08:28 pm »
Industrial strength Velcro strips work well. -- or since you have the holes drilled and the bracket you could use a plastic zip tie long enough to feed through the holes and zip tight.
jackiabu
« Reply #27 on: June 10, 2014, 05:09:41 pm »
pics please ???
jmike
« Reply #28 on: June 10, 2014, 10:37:44 pm »
JDFan
« Reply #29 on: June 10, 2014, 11:29:17 pm »
pics please ???
Zip tie Pic : (currently $2.50 per 100 @ harbor freight) -- Just run it through the bracket top hole into the pSU top hole out the bottom hole and through the bracket bottom hole - feed through the end and pull tight - should have plenty of strength to hold the PSU in place
jackiabu
« Reply #30 on: June 11, 2014, 04:50:16 pm »
Thanks  guys for the  tips.  :)
I decided at the end to put shorter screws.
Screws do not touch anything. And i can close and put the power supply.
jackiabu
Re: Project - Portable Arcade Ghosts 'n Goblins -finish.
« Reply #31 on: July 05, 2014, 01:26:19 pm »
update:
Well after a while.... I start install the the joystick and the bottom
crimps :-\ so many crimps. when they will invented something else?
after 2 hours
ready to play
some twinking in my plasma
and....FIGHT ;D
the system is runing HYPERSPIN
danielmarokoi
« Reply #32 on: July 05, 2014, 02:32:35 pm »
Amazing job especially the art designs :cheers:
are you connect through HDMI?
jackiabu
« Reply #33 on: July 05, 2014, 03:47:33 pm »
yes its HDMI and thanks for the compliments.
mgb
  • North East, US
« Reply #34 on: July 05, 2014, 05:02:12 pm »
Great job. I love it.
There have been so many projects posted on here over the years, it's nice to still see original ideas coming up.
jackiabu
« Reply #35 on: July 05, 2014, 11:24:05 pm »
Thanks men ;)
williamavished
  • Last login:February 02, 2015, 02:02:00 am
  • The best Computer Ever Made A500
« Reply #36 on: July 16, 2014, 02:24:39 am »
This project is allmost unique :cheers:  awesome job.
