Main > Driving & Racing Cabinets
Xbox360 pad rumble effect and Model2 emulator
BadMouth:
Just had the opportunity to test M2 with an xbox controller and I do indeed have rumble working. (In Daytona USA anyway).
XInput=1
EnableFF=1
It was fairly weak at first.
In the service menu of the game under DRIVE BD TEST, crank "roll left" and "roll right" up high and the rumble motors will shake full strength.
I didn't mess with the ffb settings in the ini file.
Here is what I have for those, but I don't recall if these are the default or the settings I had for my MOMO wheel:
;FORCE EFFECTS PARAMETERS
;FE_CENTERING Effect (Spring centering effect)
FE_CENTERING_Gain=0.5 ;Global gain
FE_CENTERING_Coefficient=10000 ;0-10000
FE_CENTERING_Saturation=10000 ;0-10000
FE_CENTERING_Deadband=1000 ;10%
;FE_CLUTCH Effect (Friction, wheel turn hardness)
FE_CLUTCH_Gain=1.0 ;Global gain
FE_CLUTCH_Coefficient=10000 ;0-10000
;FE_LEFT,FE_RIGHT (Constant force in a direction)
FE_LEFT_Gain=1.0 ;Global gain
FE_LEFT_Magnitude=10000 ;0-10000
FE_RIGHT_Gain=1.0 ;Global gain
FE_RIGHT_Magnitude=10000 ;0-10000
;FE_UNCENTERING (Sine force, wave the wheel, rumble)
FE_UNCENTERING_Gain=1.0 ;Global gain
FE_UNCENTERING_Magnitude=10000 ;0-10000
FE_UNCENTERING_Offset=-200
FE_UNCENTERING_Phase=0
FE_UNCENTERING_Period=56000
This was with version 1.0.
baritonomarchetto:
Thank you for givin this a try: i was not able to set it up correctly having no confidence with the FF options in Model2.
Will try this weekend to see if other games are rumble-ready ;)
baritonomarchetto:
Just tested, no luck.
Maybe a driver issue? I have the "accessory software" installed, not sure if you are using the same or a custom driver ... :'(
BadMouth:
--- Quote from: baritonomarchetto on January 31, 2014, 01:06:27 pm ---Just tested, no luck.
I'm using an official Microsoft xbox360 for PC controller.
It was plug and play.
I didn't install anything other than what windows installed automatically when I plugged it in (windows 7).
I threw away the disc that came with it.
I still have XP on my jukebox and my old emulator setup, but I don't know when I would get time to test it on those.
baritonomarchetto:
It could be a SO issue, but mamehooker "rumbles" perfectly by selecting the Xbox controller on it's menu test.
Well, if you (or someone else reading) will have time, please test this on XP ;))
thanks!
Navigation
[0] Message Index
[*] Previous page
Go to full version
