Author Topic: Control panel material  (Read 1614 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: September 11, 2013, 10:36:58 pm »
I'm planning on making a new control panel.  Should I use 3/4" plywood or MDF?  Which material is easier to work with - is one more of the harder wood?
Re: Control panel material
« Reply #1 on: September 11, 2013, 10:42:15 pm »
Stainless steel.
severdhed
  • Online Online
  • Last login:Today at 08:19:20 am
  • RIP Dinosaur Hippo
« Reply #2 on: September 11, 2013, 10:43:57 pm »
i always used particle board for my panels, until the last one i made i used MDF...and i loved it...it is so smooth and easy to cut, i highly recommend MDF
mgb
  • North East, US
« Reply #3 on: September 11, 2013, 11:48:56 pm »
MDF will be the easiest to work with and the cheapest.
  • Last login:Today at 04:11:49 am
« Reply #4 on: September 12, 2013, 12:10:21 am »
MDF is good stuff as long as you:
1. Make sure to use proper eye and breathing protection.
2. Remember that the dust gets *EVERYWHERE* -- work it outdoors with the garage door closed, if possible.
Richardgregory
« Reply #5 on: September 12, 2013, 09:30:03 am »
Thanks all - MDF it will be then.   I"ll pick up the piece on the wknd.
Cheers
zanna5910
  • Last login:August 05, 2024, 10:37:36 am
« Reply #6 on: September 12, 2013, 09:53:08 am »
Cheers
next thread - "Which store should I buy mdf from?"
JK, good luck with your build.
