Author Topic: I'm Quite Chuffed...  (Read 19225 times)
  • Last login:Yesterday at 03:34:59 am
« on: September 05, 2013, 02:25:32 pm »
Did my first keyboard encoder hack today (slow day at work). It. Was. AWESOME.
Re: I'm Quite Chuffed...
« Reply #1 on: September 05, 2013, 02:29:54 pm »
I'd like to try that one of these days
« Reply #2 on: September 05, 2013, 02:40:11 pm »
I used a wire and the Keyhook program on the Utilities page.
TopJimmyCooks
« Reply #3 on: September 05, 2013, 02:52:40 pm »
better to chuff than chunder I always say.
« Reply #4 on: September 05, 2013, 03:07:26 pm »
Shut the chuff up, Jimmy!
« Reply #5 on: September 05, 2013, 03:58:00 pm »
How funny- I've popped open 3 identical HP keyboards, and all three of them have different encoders inside, even though externally they're clones.
dgame
  • I am no Jedi
« Reply #6 on: September 05, 2013, 05:28:45 pm »
Man, you guys are retro . . .
« Reply #7 on: September 05, 2013, 05:32:43 pm »
It was quite exhilirating, really. It's like the first time I messed with an actual arcade monitor. I'm one of those that started in this hobby thinking he was going to use a Tankstick, so every little new thing I've learned has been a blast.
Louis Tully
« Reply #8 on: September 05, 2013, 06:12:16 pm »
« Last Edit: February 12, 2015, 03:55:16 pm by Louis Tully »
« Reply #9 on: September 05, 2013, 06:22:34 pm »
Makes sense, too. I need my jukebox to recognize the 'Esc' keypress and the '5' keypress. That's it. With my handy map that I made, now I can do that!
05SRT4
  • Check out my Pow Pow
« Reply #10 on: September 06, 2013, 04:27:09 am »
Right there with you on that 100%.  :cheers:
+1 more with the same thoughts.
ark_ader
  • I glow in the dark.
« Reply #11 on: September 06, 2013, 06:23:15 am »
I'm disappointed that you are doing a task that would better be served by an encoder like KADE, which would bring revenue to those who bring innovation to this hobby.
05SRT4
« Reply #12 on: September 06, 2013, 06:52:40 am »
Hey yotsuya, how much for a hacked keyboard encoder?
degenatrons
« Reply #13 on: September 06, 2013, 07:18:53 am »
Hacking keyboards is an interesting challenge for those that want to take it on and a good way to learn some basic electronics.  I hacked a few when i got started out in this hobby and they worked well.  Had some trouble with blocking on my first attempts but that was my own fault because I didn't test all the combos before doing the hack.  I learned and got a bit smarter using a scan of the keyboard membrane and color-coding all the traces using photoshop - to limit the number of conflicts.  To do it properly took me a long time and was very frustrating.  These frustrations motivated me to learn about AVR's and to come up with easier solutions.  No reason why folks shouldn't continue to hack keyboards if they have the time and the inclination to do so.
« Reply #14 on: September 06, 2013, 12:05:51 pm »
Thanks, Degenatrons! I've always read about keyboard hacks, but in this day and age of quality encoders, I obviously never had to do one. This was a special case, though: my touchscreen jukebox project (which is 98% done) needed two keystrokes: ESC to exit the jukebox program, and 5 for credit. I ended up getting a Xin-Mo to handle those keypress functions because the jukebox program can handle joystick commands, but the program I am using to output music videos doesn't play nicely with joysticks, so I would absolutely NEED an ESC command to exit back to the main menu. Yeah, I know, I could either run JoyToKey or make an AHK script to do that, but I wanted to try something that ran natively and quickly, without adding another potential issue. I want users to be able to go to the juke, pick a song, push the big lit blue button to exit back to the menu, rinse and repeat. I don't need any failures along those points.
It just didn't make sense to me to pay full-price for an encoder for 2 keypresses, so I took the plunge with a broken keyboard. Took me 30-40 minutes to completely map out the matrix. When I go home, I had to scrape off the protective coat on the contacts in order to solder wires directly to the PCB. I reinforced the solder points with hot glue, then I connected the wires to two separate Molex connectors after I tested to make sure they still worked (they did!). I then hacked my internal wiring to the menu and credit buttons, taking off the Xin-Mo connector and putting on the appropriate Molex to interface with the keyboard PCB. Closed everything up, ran some tests, and everything is working exactly as it should!   :w00t :gobama I'm thrilled because I finally did a keyboard hack!!! Having said that, if I were wiring up a control panel, there's no way I would do a keyboard hack for that! For two buttons, yes. For 20+, hell no.  >:D
TL,DR version: Piss off, Ark. It worked.
« Last Edit: September 06, 2013, 12:07:58 pm by yotsuya »
Hoopz
  • Intellivision Rocks!
« Reply #15 on: September 06, 2013, 12:29:05 pm »
Good job on the hack.  And thanks for the post summary.   :applaud:
ark_ader
« Reply #16 on: September 06, 2013, 05:08:08 pm »
Makes more sense to spring $20 than to burn your fingers.
Keyboards hacks are not always a perfect solution.
« Reply #17 on: September 06, 2013, 05:28:11 pm »
It cost me zero dollars and no burned fingers.
In this case, it was the PERFECT solution.
DillonFoulds
« Reply #18 on: September 07, 2013, 10:52:56 am »
Burnt fingers? That's cute. Not exactly a concern...
CoryBee
  • Bopity Boopy
« Reply #19 on: September 07, 2013, 11:08:02 am »
Ooo fancy pants SMD soldering. Well good sir, you aren't the only one with such skills!
GOOD DAY!
  • Last login:February 13, 2026, 05:20:07 pm
« Reply #20 on: September 07, 2013, 12:26:11 pm »
+1
« Reply #21 on: September 12, 2013, 01:20:50 am »
Oh man..... September is turning out to be the chuffediest month in the history of me being a collector.
« Reply #22 on: September 12, 2013, 01:51:13 am »
What's keeping you Chuffed this fine evening, brother?
I have to say, I have been chuffed myself as well, I have been doing a tube swap from an old tv and whether or not it will work doesn't matter so much. It has been positively exhilarating simply learning something new that was once considered daunting.
« Reply #23 on: September 12, 2013, 02:01:42 am »
This month - ---steaming pile of meadow muffin---, these 11 days, I have...
1. Finished a JAMMA cab for a friend of my wife's...
2. Almost completed a build as a birthday present for my best friend (with the awesome HaRuMaN's help)...
3. Completed my jukebox build that was two years in the making...
4. Almost finished a project Nephasth has been helping me with (I promised him I'd make a thread when it's done)...
and tonight, I picked up an empty cabinet that I have wanted for soooooooooooooo long...
Quite, quite chuffed indeed.
05SRT4
« Reply #24 on: September 12, 2013, 02:03:58 am »
You sir are on fire!!
« Reply #25 on: September 12, 2013, 02:06:28 am »
I'm especially proud of the juke because I built it all by hand, and the Neph project because it's pretty awesome.
« Reply #26 on: September 12, 2013, 02:09:12 am »
Oh, here's a sneak peek at what I picked up tonight...
« Reply #27 on: September 12, 2013, 02:17:24 am »
 :o Wow, dude you were not exaggerating one bit.  That is indeed a lot of chuff inducing goodness. I await the Neph magical mystery thread with anticipation. :applaud:
I don't think I will ever guess what cab you picked up.  ;)  I look forward to see what you do with it.
« Reply #28 on: September 12, 2013, 02:39:27 am »
Funny thing is, I wasn't even looking for the cabinet. I was picking up a coin door for my friend's project at a local collector's house, The guy was just showing me some extra cabinets he had; I saw this one, asked him how much, & next thing I knew, we were loading it in my vehicle.
« Reply #29 on: September 12, 2013, 10:57:50 am »
I didn't help you, you built that all on your own! :cheers:
« Reply #30 on: September 12, 2013, 11:14:13 am »
He's a big boy now!
« Reply #31 on: September 12, 2013, 11:26:11 am »
« Reply #32 on: September 12, 2013, 01:09:03 pm »
You hooked me up with the components, feedback and guidance. I'd say that's help!
rpgposer
  • Last login:August 31, 2018, 11:46:12 am
  • PSO lover.
« Reply #33 on: September 12, 2013, 04:56:30 pm »
And your wallet was empty...
Never met a game I won't keep.
« Reply #34 on: September 12, 2013, 06:06:23 pm »
I had enough, that's all that matters.  :cheers:
« Reply #35 on: September 15, 2013, 12:19:58 am »
Another weekend of firsts- I necked my first tube tonight. >:(
« Reply #36 on: September 15, 2013, 12:50:46 am »
« Reply #37 on: September 15, 2013, 01:58:11 am »
Yep. 21 inch CRT monitor I had been saving for two years JUST for a Star Wars project. $5 down the drain.  :cheers:
TopJimmyCooks
« Reply #38 on: September 15, 2013, 09:23:46 am »
stay strong bro.
« Reply #39 on: September 15, 2013, 10:30:29 am »
I came here for two porpoises.
1) Yay!  The SW begins in earnest now right?!
B) You told ark to piss off.  heh, chuckle snort
