Author Topic: measuring wire gauge.  (Read 1092 times)
SavannahLion
« on: July 07, 2013, 04:57:28 pm »
What tool is used to measure an unknown wire gauge?
Wikipedia shows a picture of a tool used for such purpose but here's the funny thing, it doesn't give the device name. My wire stripper has a gauge measuring portion but it doesn't go down past 24 gauge or so. I believe that's right where cat5 is.
is it reasonable to estimate smaller gauges if I wrap it around a rod and figure it out from that? Eg 24awg is right around .5mm diameter therefor two turns would be 1 mm width on the rod ergo twenty turns would be about 10 mm. Same for the other diameter gauges?
SavannahLion
Re: measuring wire gauge.
« Reply #2 on: July 07, 2013, 05:31:17 pm »
Nice one. Thanks. :cheers:
  • Last login:Yesterday at 09:31:59 pm
« Reply #3 on: July 09, 2013, 05:08:28 pm »
If you have a micrometer, you can measure the diameter of the conductor then use this chart. (Although I dont agree wit the listed curent capacities, so you may need to double check with another source. I googled "meaure wire gauge with a micrometer")
http://www.powerstream.com/Wire_Size.htm
