Author Topic: fooling with m2emu network  (Read 205775 times)
0 Members and 8 Guests are viewing this topic.
AMG KC
  • Last login:June 29, 2022, 05:33:52 am
Re: fooling with m2emu network
« Reply #200 on: April 21, 2019, 02:15:55 am »
Ah so you feed the car data into memory directly. Pretty neat idea. Keep it up :)
Hi :) I have a few questions to add.
Im a bit muddled on what the status of Indy 500 multiplayer is, will it run well now and be completely playable?
What is the best way to run it with 3-5 players?
How do i run that lua file you made for it?
Do you find XP x64 runs better for this or other Windows versions?
Hydreigon
  • Last login:October 11, 2023, 09:57:11 pm
« Reply #201 on: April 21, 2019, 10:53:18 am »
Running Indy 500 multiplayer (or any model 2 game) would most likely require that m2lagfix. Speak of m2lagfix, I would like to know the current progress on that (or a new version of m2emu updated for later operating systems). Sadly, the only way to run these Model 2B or 2C games is to exit test mode at the same time. Very finicky network coding atm.
MrThunderwing
  • Last login:August 19, 2025, 02:18:43 pm
  • As I pass, do I give you the ass or the crotch?
« Reply #202 on: April 21, 2019, 12:13:13 pm »
In the past I've been able to get a 2 Player with the 'regular' Model 2 Emulator network function working - it's just highly temperamental. I don't know if the thing about both systems having to exit the test mode at the same time is true or not, I think it's just if there's any lag between the two it causes an instant network failure.
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
« Reply #203 on: April 21, 2019, 04:22:26 pm »
you have all the reason that it will have to be "automated" but also I am more than sure that we are advanced in question of "nowadays we can do it" many years passed and it is time to work on it.
I'm ready for whatever
Boomslang
  • Last login:January 01, 2024, 08:20:43 pm
« Reply #204 on: April 22, 2019, 03:52:07 pm »
Theres a lua fix to indy 500 that Sailorsat made
I've got it somewhere so I'll try post it
At least 4 players works fine now with it
AMG KC
« Reply #205 on: April 23, 2019, 01:58:24 am »
Yeah mate i found that worked too, i dont know if im using m2lagfix or not, no idea how to tell if it is working or if the emulators are still just talking direct and ignoring the lagfax file.
Be nice if we could get it all to run as smooth and synced as Sega Racing Classic does!
XSFDriver
  • Last login:May 28, 2023, 11:02:22 pm
« Reply #206 on: May 13, 2019, 04:46:04 am »
That'd be appreciated, if you could, please Boomslang.... I'm slowly collecting hardware to put a 4 Player system together in the future... and Indy 500 is one of the main Model 2 games I'd like to run on it (Don't want to know how much $$$ I pumped into that machine in the arcade back in the day).
But... until then... just reading and learning... and collecting stuff to try out when I get time... and a new garage to set it up in :lol
Thanks again to all of you who put all this effort into making these old classics more manageable on what we have access to today, Cheers.. :cheers:
AMG KC
« Reply #207 on: May 13, 2019, 05:39:05 am »
Itd be good if someone could take the network system from Sega Racing Classic and implement that into Model 2 emulator, it works beautifully with no jolting cars or lag at all, even when 1 machine is running at 60Hz and another is 75Hz, which ive noticed caused issues with M2 Emulator networking.
vandale
  • Last login:September 11, 2024, 07:07:45 am
  • Id 10 and t error
« Reply #208 on: June 07, 2019, 10:41:17 pm »
Gday mate, I am hoping you can help with my lua file for indy500. Currently its this:
require("model2")
function Init()
end
function Frame()
   local state = I960_ReadByte(0x202098);
   local state2 = I960_ReadByte(0x20209C);
   local state3 = I960_ReadByte(0x2020AC);
   if state==3 and state2==5 and state3==1 then
      Model2_SetWideScreen(0)
   else
      Model2_SetWideScreen(1)
   end
end
And I need to add this:
require("model2");   -- Import model2 machine globals
function Frame()
   I960_WriteDWord(0x005ec6b0,0x00000000)
end
do I simply paste it in like this?
require("model2")
function Init()
end
function Frame()
   else
   end
end
Ive tried and it doesn't work  :embarassed:
Please help.
« Last Edit: June 07, 2019, 10:43:39 pm by vandale »
SailorSat
  • Last login:October 11, 2025, 08:20:43 am
    • For Amusement Only e.V.
« Reply #209 on: June 08, 2019, 03:05:57 pm »
Hm... That should work. Do you get any error?
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
vandale
  • Id 10 and t error
« Reply #210 on: June 09, 2019, 07:01:20 pm »
The game won’t link at all, I get network error immediately after the screen that says master and slaves, nodes etc. if I remove the code from the script then it works fine and links but fails like it used to randomly.
Am I meant to run lagfix and the script together?
SailorSat
« Reply #211 on: June 10, 2019, 09:48:18 am »
Hm... Then I can't help.
I have "FrameSync=1" in "m2network.ini" and the script.
Other than that I didn't change anything.
vandale
  • Id 10 and t error
« Reply #212 on: June 10, 2019, 03:30:43 pm »
Do I still need to run lagfix also or does it only need the script and framesync to work?
vandale
  • Id 10 and t error
« Reply #213 on: June 11, 2019, 08:49:57 pm »
Please post a copy of your LUA with widescreen and network fix.
XSFDriver
« Reply #214 on: June 15, 2019, 09:26:17 am »
G'day Vandale, was wonderin'... (from your "G'Day mate" earlier), if you were down under as well, yeah?
...Anyway, I'm no programmer (only done a bit of "Basic" YEARS AGO), but I'm trying to get my head around the .lua scripts and how they work/what they do... I've been reading the "model2lua.txt" trying to understand the contexts, layouts of these. Also checked out the .lua scripts of other roms that were packaged in with Model2 1.1a (not that I get what they mean, but I gotta start somewhere)..... and was wondering, what this section of your lua script does exactly?-
function Frame()
end
Also, to you others who do coding, I've done a little research, but can you tell me if I'm on the right track (or not)... are the .lua scripts written in "C" programming format or something else? I can see a BIG learning curve coming up for me.
I know that I might come across as a bit of a noobie with this, but I gotta start somewhere, to understand whats going on in the background, if I'm gunna get this 4 player Model 2 system up and running in the future sometime (and mess with it's head), and I would like to help with SOME input in the future here, if possible.
Cheers.
vandale
  • Id 10 and t error
« Reply #215 on: June 15, 2019, 05:47:10 pm »
G'day Vandale, was wonderin'... (from your "G'Day mate" earlier), and was wondering, what this section of your lua script does exactly?-
function Frame()
Gday mate, haha, yes I’m in little ol New Zealand. So is Boomslang.
I wouldn’t have a clue about lua scripts and how they work. Earlier in this thread sailorsat provided the script line to assist with network errors in indy500.
I think I’m not putting it in the script correctly as it makes the network worse when I use it.
Hopefully sailorsat or boomslang or Howard or one of the other true geniuses can answer your other questions.
Chur
2huwman
  • Last login:August 16, 2025, 06:01:13 pm
« Reply #216 on: June 16, 2019, 06:07:13 am »
So ages ago I mucked around with a hack to make network work while including AI positions
I've finally coded it up over the weekend which was a massive pain to get working right but have it working really well for 2p,3p and 4p setups so far
Just start race as normal and everything happens automatically as soon as race starts, also made the results screen at end work correctly
One side effect is the AI cars are coloured like normal multiplayer cars as opposed to the normal purple but otherwise it seems to work pretty good
Would love to try this - do you have a download for the hack available please?
XSFDriver
« Reply #217 on: June 16, 2019, 07:56:00 am »
Quote:
"Gday mate, haha, yes I’m in little ol New Zealand. So is Boomslang.
I wouldn’t have a clue about lua scripts and how they work. Earlier in this thread sailorsat provided the script line to assist with network errors in indy500. "
Cool, just a stones throw across the pond ;D  ...Me and the Mrs. want to go there sometime (I'll have to ask ya's where the good arcades are, when we go 8))
And thanks for the reply Vandale... I went back and re-read page 4 of this thread (for about the 6th time)
...so you're using the "Indianapolis500 (Rev A, Deluxe)" rom yeah? I'm curious about the "Patched Indy500 Rom" that Sailorsat mentioned in that section. The 4 PC's I've got shouldn't have any issues running at 60FPS as I've already collected heaps of matched ram and 1GB graphics cards for them, they'll all be identical so they should all run at the same performance.
Man, reading this stuff makes me want to get it all out of storage and start hookin' things up... just don't have the space at the mo'... I'm currently doing a full resto' of my car AND trying to get a few things sorted out on the house... but, one day. ::)
Cheers :cheers:
« Last Edit: June 16, 2019, 09:45:49 am by XSFDriver »
SailorSat
« Reply #218 on: June 20, 2019, 04:25:27 pm »
So... I just tried it (again).
m2emulator 1.1a - "Indianapolis 500 (Rev A, Twin, Newer rev)"
m2network.ini (master)
Code: [Select]
[Network]
RxPort=7001
NextIP=127.0.0.1
NextPort=7002
FrameSync=1
m2network.ini (slave)
Code: [Select]
[Network]
RxPort=7002
NextIP=127.0.0.1
NextPort=7001
FrameSync=1
indy500.lua (master and slave)
Code: [Select]
function Init()
end
function Frame()
end
works like charm
Hydreigon
« Reply #219 on: June 22, 2019, 01:20:43 pm »
Wave Runner also has a network error type screen. Idk if you managed to patch that out or not?
XSFDriver
« Reply #220 on: June 23, 2019, 08:07:06 am »
Hi Sailorsat, THANKS HEAPS for going over that, with the indy500.lua... Like you said "Works like a charm"... I finally got it networking on two PC's with the following:
Code: [Select]
[Network]
Framesync=1 ; test for stopping flickering cars
RxPort=1978
NextIP=192.168.1.2 ; sends info to this ip
NextPort=1978
Code: [Select]
[Network]
RxPort=1978
NextIP=192.168.1.1 ; sends info to this ip
NextPort=1978
...and NOW with your .lua script on both:
Code: [Select]
function Init()
end
function Frame()
end
...at first, I had the two PC's just hooked up with a crossover cable, then I hooked them up with normal network cables and a router, but with both attempts I can NOW network them successfully and play the game linked, but I still get flickering rival cars (same on Daytona USA). :banghead:
Is there something I'm missing or do you think it's the two primitive PC's I've used for the test?
PC 1:
MOBO: Intel D945GTP
CPU: Intel Pentium "D945" (early Dual Core) 3.4GHz
Ram: 3Gb
GPU: Nvidia Geforce 8400 GS 512Mb
OS: XP SP2 32bit
PC 2:
MOBO: Intel D865GLC
CPU: Intel Pentium 4 (Hyperthreaded) 3.0GHz
Ram: 4Gb
GPU: ATI Radeon HD 3650 AGP 512Mb
OS: XP SP2 32bit
I've been reading this thread over and over, trying to learn more and be able to mess with these things myself. I was thinking maybe your "M2Lagfix.exe" might help this glitch?
...Any help or guidance to understand what's going on would be greatly appreciated, I know you're busy with lots of projects though.
Cheers. :cheers:
vandale
  • Id 10 and t error
« Reply #221 on: June 23, 2019, 04:38:15 pm »
…….works like charm
Thanks heaps
XSFDriver
« Reply #222 on: June 24, 2019, 07:30:08 am »
So it turned out, I cannot hook the vsync the way I wanted to do.
However there still is light at the end of the tunnel :D
Small LUA patch to "disable" the infamous "NETWORK ERROR" in Indy500 and Motoraid - turns out the code has some "delay" counter going up till 0xFF, and then deeming the network unreliable. By writing 0 (read ZERO) to this counter every single frame we can be sure to never reach that value. - Not exactly the way I wanted to fix things, but still should be enough to get a "stable" 8 player setup running.
indy500d.lua
Code: [Select]
function Frame()
I960_WriteDWord(0x00555214,0x00000000)
end
indy500.lua
Code: [Select]
function Frame()
end
motoraid.lua
Code: [Select]
function Frame()
I960_WriteDWord(0x005195d4,0x00000000)
end
OK... so this is to set this "delay" counter to 0...to go around this network error...just curious...by what way do you find this address/value in each rom? Can anyone shed some light on this for me?
E.G. I960_WriteDWord(0x005ec6b0,0x00000000)
Cheers.  :cheers:
« Last Edit: June 24, 2019, 07:34:00 am by XSFDriver »
SailorSat
« Reply #223 on: June 24, 2019, 10:25:25 am »
Phew… Single step debug (in MAME) every time the host cpu tries to communicate with the comm boards.
Taking notes, more debug... once in a while feeling funny and changing some memory values on the fly :D
XSFDriver
« Reply #224 on: June 25, 2019, 09:16:28 am »
...and a LOT of patience and persistence by the sound of it... Thanks for the reply Sailorsat, you've given me a new respect of all the work you lot put in, I'll look into the MAME debugging, not that I'll understand it, but it's a start.
Cheers.  :cheers:
gareth_iowc
  • Last login:October 04, 2022, 03:27:37 am
« Reply #225 on: November 26, 2019, 07:25:05 pm »
Do i run m2lag fix on every machine or just the spectator?
vandale
  • Id 10 and t error
« Reply #226 on: October 13, 2021, 09:37:04 pm »
Yes - next step will be replacing that hardcoded stuff with dynamic values.
Hi Sailorsat.
Ive finally setup a live screen on my twin daytona and was curious if you ever added the dynamic values to allow just a 2 player setup with live link?
Many thanks
SailorSat
« Reply #227 on: October 16, 2021, 11:43:26 pm »
To be honest - I don't remember :D
I did a lot of additions, but I'm not sure if it works in a 2-player setup correctly.
Nuexzz
« Reply #228 on: October 17, 2021, 11:53:26 pm »
would be great to try with 2 players  ;D
vandale
  • Id 10 and t error
« Reply #229 on: October 19, 2021, 03:52:22 am »
I agree. I have Sega Rally and Daytona 2 running the live system and its awesome!!!
vandale
  • Id 10 and t error
« Reply #230 on: October 19, 2021, 03:53:34 am »
Ok thats cool, Im willing to have a play around with the software on my twin, where can I acquire your scripts etc?
MrThunderwing
« Reply #231 on: October 21, 2021, 09:00:13 am »
Hey, I'm just jumping in here having just skimmed through the recent comments in the thread, but for Daytona USA 2 if you want a live cam, all you need to do is add an extra machine in to your network and configure it as a live cam in the test menu.
If you add an extra Sega Rally machine into your Model 2 Network, I think it'll automatically default to a live cam if no one's playing on it. I did some single PC 3 player games of Sega Rally awhile back, but I opened the emulators up in a 4P network, so that when I used the desktop option to 'display windows side-by-side' it kept them in the right aspect ratio. The player 4 window turned into a live cam, and I can't recall actually changing anything in the test menu to make it do that. This is all without lagfix or any scripts BTW.
« Last Edit: October 21, 2021, 09:16:44 am by MrThunderwing »
SailorSat
« Reply #232 on: October 22, 2021, 03:43:07 am »
Yup, I think Indy 500 and STCC do the same - they switch between attract mode and "live cam" every 30 seconds or something like that.
vandale
  • Id 10 and t error
« Reply #233 on: October 25, 2021, 04:15:12 am »
Yup Im running both those games in live mode. Its Daytona I want to add though and the information and files seem very illusive.
Sixfortyfive
  • Last login:May 16, 2025, 07:53:33 pm
« Reply #234 on: October 27, 2021, 05:13:48 am »
Oh cool, this thread is still kind of active. I e-mailed you about this a couple days ago SailorSat and have been playing around with the Daytona live spectator program and trying to get it to work. For the time being I'm using the files and instructions in this post since it's the most complete and straightforward explanation I've seen so far. I haven't messed around with the other tools you linked very much yet since some of the config files in there are a little different and I'm trying to take this one step at a time and not bombard everyone with too many troubleshooting questions.
Anyway, I'm trying to set up a full count of 8 Daytona game sessions plus a spectator on one computer, just for the sake of testing for now. The 8 actual game sessions are fully booting and running correctly, which suggests that the lagfix tool is configured correctly, but the spectator session gets stuck on the "NETWORK CHECKING" screen and never advances, and I can't figure out the cause. For what it's worth, the stats program does seem to correctly identify the instance of the emulator that is meant for spectating; the overlay wraps around that specific emulator window.
These are all of the config files:
The top 8 docs are the m2network settings for each of the 8 player stations.
On the bottom, the first doc is the m2network settings for the spectator station, followed by the config files for the stats and lagfix tools.
On the player stations, car 1 is set to Master and the rest to Slave. The spectator station is also set to Master and car 1; it wasn't clear to me whether this was correct or not.
All other game settings are identical between emulators, and they're all running the "Saturn ads" version of the game. The cabinet type is set to "Special" for all of them.
All IP addresses in these files are set to localhost since it's all running on one PC at the moment.
Did I mess up the port assignments somewhere or is something else the cause?
EDIT: Also, uh, when I started messing around with these tools, my laptop keyboard's Windows key stopped working. If I plug in a USB keyboard or use the Win10 OSD keyboard, the key functions fine on those. I've tried several googled suggestions for fixing this but no luck. I guess there's a chance that this might be an unrelated hardware failure but just throwing this out there.
« Last Edit: October 27, 2021, 07:00:14 am by Sixfortyfive »
SailorSat
« Reply #235 on: October 27, 2021, 05:56:25 am »
I'll try to get my lazy ass up and check the stuff and provide some instructions on how to use it.
vandale
  • Id 10 and t error
« Reply #236 on: October 27, 2021, 11:51:15 pm »
Yay!!!!!!!!!  :applaud:
SailorSat
« Reply #237 on: October 28, 2021, 05:54:47 am »
Holy crap... Virus detections nowaday seriously are paranoid... "Possibly sketchy software" because I do socket operations and memory injection...
Anyway...
Notes for "same machine use":
- run the main emulators using "emulator_multicpu.exe"
- run the live spectator using "emulator.exe" (because is checked first).
The LiveStats will use the "last active" window called "Daytona USA (Saturn Ads)".
It uses two "full screen" windows - if there is no second screen, the map view can't be seen.
!! DON'T start a race with Car No.1 !! - Start with any other car and have Car No. 1 join in.
Speed will always be shown as km/h (sorry folks ;))
Tested with 2, 4 and 8 players. (other sizes should work too.)
Sixfortyfive
« Reply #238 on: October 28, 2021, 12:06:39 pm »
Thanks. It seems that it's almost working for me, but not quite. This time the spectator gets past the network check, but the stats display doesn't actually load. Interestingly enough, if I kill the spectator emulator, then the stats program seems to attempt to hook into the player 1 station. Not sure what's going on.
EDIT: PLEASE MUTE THIS VIDEO LOL. Seems that OBS didn't use my desktop volume setting, so you get 9 copies of Mitsuyoshi belting the attract demo at you.
I made another attempt with a full 8 players, and then another attempt where I left the spectator emulator in fullscreen. Same result.
These are my config files:
EDIT 2: Oh, of course. If I insert coin on the spectator machine then the stats hook into that station correctly. So nevermind, for the most part.
The spectator station's HUD still spreads out across the whole monitor instead of staying confined to the emulator window, but I assume that's just a limitation of the program?
« Last Edit: October 28, 2021, 12:24:34 pm by Sixfortyfive »
SailorSat
« Reply #239 on: October 28, 2021, 01:02:35 pm »
Ah... I see...
I guess you are missing the patch-script for the special inputs.
https://raw.githubusercontent.com/SailorSat/daytona-utils/master/src/scripts/daytonas.lua
