Author Topic: Monitor on Fire help? .. newbie ...  (Read 4282 times)
kronic24601
  • Last login:June 24, 2014, 03:08:54 pm
  • Evil Arcade Monkey Strikes Again!
« on: June 01, 2013, 05:00:36 pm »
So I was playing my PPII the other day and the screen goes black and I start to smell smoke. After closer inspection, the moment I plug in the cab a fire starts in a section of the Monitor. (I've attached a photo). Due to my ignorance, I cannot tell if this is a specific piece I need to replace, the whole chassis, or what? ...
Yes, I know that monitors are dangerous and I know about the need to discharge, etc...
Anyone have any thoughts?
nurmix
  • Last login:October 02, 2023, 03:10:00 pm
  • And now for something completely different...
« Reply #1 on: June 01, 2013, 05:12:25 pm »
Time for a new flyback transformer. Probably a HOT (high output transistor) as well. Do you know the monitor chassis make/model? Bob Roberts (therealbobroberts.net) has those parts for most monitors.
kronic24601
Re: Monitor on Fire help? .. newbie ...
« Reply #2 on: June 01, 2013, 06:32:50 pm »
There is a sticker on that component that says:
Chassis = NMX-L21G
Model = TM-2026
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 01, 2013, 07:14:36 pm »
MatsuSHITa monitor.
kronic24601
« Reply #4 on: June 01, 2013, 07:19:21 pm »
So is there a suggested part I should get? I'm flying blind here ... or should I just contact Bob?
 http://therealbobroberts.net/parts.html#flyback
mgb
  • North East, US
« Reply #5 on: June 01, 2013, 08:33:12 pm »
Yeah, if you any doubt, just contact bob with the model number and he will steer you right.
You'll want the Flyback and Horizontal Output Transistor.
  It's a good time to do a cap kit also
  • Last login:February 20, 2026, 07:25:33 pm
« Reply #6 on: June 01, 2013, 08:40:35 pm »
dude, fire!
*click*
 :lol
lcmgadgets
« Reply #7 on: June 01, 2013, 09:02:42 pm »
 :oh holy crap!
« Last Edit: June 13, 2013, 10:35:34 am by lcmgadgets »
Professor Hayashida
« Reply #8 on: June 01, 2013, 10:12:56 pm »
kronic24601
« Reply #9 on: June 01, 2013, 11:40:52 pm »
Bob suggested some parts ... will order them and see how things go. Will report back ...
kronic24601
« Reply #10 on: August 24, 2013, 01:53:56 am »
UPDATE: So, I finally got around to installing the new Fly-back and the Cap kit. However the picture is VERY VERY dark. It takes like 10min to even see it at all.
1) The Cap kit was not complete. The Bob Roberts kit didn't include all the required caps for the chassis ... so that's still pending.
2) Also, I didn't replace the HOT (actually there are two). I tested with a multimeter and it seems fine ...
What else could it be?? Should I bother with the remaining caps? Thoughts?
MonMotha
« Reply #11 on: August 24, 2013, 03:32:21 am »
After replacing the flyback, you may need to tweak the screen control on the (new) flyback.  This affects overall brightness A LOT.  You'll probably have to tweak focus (also on the flyback), too.
Do you know if the monitor worked prior to exhibiting flames?
« Reply #12 on: August 24, 2013, 11:58:53 am »
agreed. most replacement flybacks come with the screen control turned all the way down so they don't fry the tube when they get first powered on.
kronic24601
« Reply #13 on: September 04, 2013, 09:27:33 pm »
Yes, it used to work fine. Unfortunately this fly-back has no brightness adjust ... only a focus adjustment. I wonder if I'm missing something ...
« Reply #14 on: September 04, 2013, 10:58:08 pm »
it should have 2 controls one "focus" and one "screen" (sometimes labeled as "G2")
i have yet to see a flyback with only one control.
ed12
« Reply #15 on: September 04, 2013, 11:02:12 pm »
excuse me brightness is not screen
>this fly-back has no brightness adjust ... <
that is a control on a control board
please get the terms right
ed
kronic24601
« Reply #16 on: September 04, 2013, 11:33:12 pm »
Fair-enough ... this flyback does not have a screen adjust capabilities. My K7000 works as the Lilshawn photo shows, but this Matushita for the Pole Position only has one pot to adjust for the flyback, and it is focus ...
If you look up at my original photo, you can see it there. There is only 1 pot. When I replaced the flyback, aside from the points that were soldered directly onto the board, there were only 2 wires coming out of it. one goes to the monitor ... the other to the focus pot ... there is nothing else to adjust ...
here is a photo of the replacement flyback ... it doesn't include the any pots ...
http://i205.photobucket.com/albums/bb270/leinhit/Jr%20Pacman/100_3010.jpg
« Last Edit: September 04, 2013, 11:41:23 pm by kronic24601 »
« Reply #17 on: September 05, 2013, 12:01:33 am »
that is bizarre. The only time i've seen anything like that was on the old 3 tube projection TV's. they had one BIG flyback that ran into a focus/screen network box with 6 adjustments (2 for each tube)...then branch out to the 3 tubes.
this might be a similar implementation.
your "screen" control might just be somehow manually adjusting the B+ or something feeding the actual flyback to produce more/less high voltage. be sure to read the voltage with a meter to verify it's level.
check this schematic manual on page 29 (pdf page 35): http://arcarc.xmission.com/PDF_Monitors/Atari%20Monitor%20TM-202%201st%20Printing%20Matsushita%2019in.pdf
this monitor should be pretty much the same as yours.
kronic24601
« Reply #18 on: September 05, 2013, 01:23:50 am »
Thanks ... I'll take a look at that, I feel like I fiddled with the B+ adjustment dial, but I didn't use a voltmeter to set it exactly ... it's work a shot.
