Author Topic: 4-6" dia. material  (Read 1924 times)
mw
4-6" dia. material
« on: November 08, 2003, 08:19:11 pm »
I had a dream...
What I'm looking for is a translucent material that could be lit from the back, but is bendable to anywhere from 4-6" diameter bend. The actual material needs to be able to withstand some abuse.
To spell it out I want a tube cut in half. Something like this ?
Overhead view: ('U' is the peice I'm looking for)
| ____|
U       U
Optional materials would work, that aren't translucent would be appreciated too. Plywood/benderboard is one option... Not sure what the actual bend radius is though ?
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
Re:4-6" dia. material
« Reply #1 on: November 08, 2003, 09:48:30 pm »
You can heat up plexi or lexan and bend it into the shape you need.  If you want it to be strong though that would meen pretty thick plexi which would probably be pretty ard to shape.  If you look around at computer modding stuff people make all kinds of crazy stuff with plexi including makeing it into full tubes.  I have also seen some pretty crazy car audio boxes made with plexi to so it should work.
  • Last login:October 27, 2025, 02:12:45 pm
    • GroovyGameGear.com
« Reply #2 on: November 09, 2003, 10:40:04 am »
Not quite sure what you are after, but you can buy clear Acrylic (plexi) in large cylindrical shapes.  Be warned though, they are quite expensive.
Maybe if you offered more info?
mw
« Reply #3 on: November 10, 2003, 01:54:41 pm »
Thanks, I'll have to play with some Acrylic. Not sure I'll have time anytime soon to do this but if I get the details ironed out it will make it easier to do later.
Here's a quick sketch of what I mean. The base will have columns on each side that blend into the side, more of a jukebox look.
« Last Edit: November 10, 2003, 01:57:56 pm by mw »
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #4 on: November 10, 2003, 01:57:06 pm »
uhhhhhhhhhhhhhhhh...
That's not a sketch :)
mw
« Reply #5 on: November 10, 2003, 01:58:22 pm »
Sorry, It is now  ;)
cj1
  • Last login:January 16, 2007, 03:47:57 pm
« Reply #6 on: November 10, 2003, 08:23:12 pm »
You might find something here:
http://www.modernplastics.com/
Click "E-Commerce", then "Industrial Plastics Tube". Or just poke around and see what they've got. I know you're not exactly looking for a tube, but you might find something there that I didn't.
Just ordered some tinted plexi from them, and their prices seem pretty reasonable. (Except for shipping, but I ordered a 24 x 48 sheet, which is probably considered oversized for shipping purposes.)
eightbit
  • Last login:September 07, 2019, 07:38:11 pm
  • My cab is never done...
« Reply #7 on: November 10, 2003, 09:38:23 pm »
I think they sell clear dust collector tubing in 4-6" diameters.
My statements are my own opinions. They have the value that the reader gives them. My opinion of my opinion varies between foolish and brilliant and these opinions often change with new information.
Hammerbot
  • Last login:September 04, 2005, 10:40:51 am
  • All work and no play...
« Reply #8 on: November 11, 2003, 09:00:39 am »
If you bend the plastic, use a form and make sure to let it COMPLETELY cool on the form.
I had a bad experience trying to bend 4 different pieces. I let them cool for a while and then set them one at a time to do the next piece.  They all wound up cracking because they didn't cool completely before I removed them.  They got a little additional bending from the weight of the material and took on a twist initially and then cracked.
That was a bummer to say the least.
mw
« Reply #9 on: November 11, 2003, 07:56:47 pm »
Thanks everyone. Think it's time to get the yellow pages out. Sure there's something locally. Modern Plastics has stuff that will work.
Think I might try to do it myself first  :-\
Anyway Thanks to everyone, this has been bothering me for awhile now.  8)
cj1
« Reply #10 on: November 11, 2003, 09:01:35 pm »
Clamps... lots of clamps.
I just had my first experience bending lucite - just a simple 90 degree angle. Sandwiched one side between two pieces of wood. The wood was slightly bowed however, so there was a little give in the center (it was only clamped near the ends). This give was enough to make the curvature of the bend different in that area and the entire piece ended up crooked. ugh. Tried again, clamping more securely, and the results were adequate.
Your idea looks really cool. Good luck!
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #11 on: November 11, 2003, 11:09:08 pm »
You know we can't see the paper on your desk that you are sketching on, right?
This opinion was created from 100% post consumed information.
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #12 on: November 12, 2003, 01:49:17 pm »
Buy a tube and cut it in half. I couldn't find tranparent tubes that were 37" high though, but if you can it would be way easier than try to bend sheets.
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #13 on: November 12, 2003, 02:07:02 pm »
If art deco goes with your decor, you could use glass end blocks.
I can see it now with pastel colors and brushed stainless trim...
Bob
