Main > Software Forum
Troubleshooter 2: Shoot Harder
Endprodukt:
TS2 doesn't work for me in M2.
Here is what happens:
Can only move in diagonals with both guns (top left to bottom right) in HOTD, VCOP and VCOP2. I can only shoot in HOTD. VCOP 1+2 doesn't register any triggering at all. Tried with a fresh install and got the same results. I tried it through TS2`s Model 2 Testmode with rawmode activated and deactivated.
Howard_Casto:
Darth Marino : That's what I run, so I'm not sure what you are missing.
Endprodukt Sounds like you haven't calibrated in the model 2 menu. If it's a fresh install then the nvram files aren't there, so the guns won't move properly even without the troubleshooter.
You haven't given me enough information btw.... what kind of guns are you using ect....
Raw input needs to be activated in model2's emulator.ini and the ids set to a number higher than all of your mouse devices for buttons to work in vcop and vcop 2. TS2 attempts to do this for you automatically.
Also make sure you have the right ids set in ts2. When running a game in windowed mode, you can double click on the icon in the task bar to make the ts2 debug window appear, when you move your gun (assuming it's IR), you should see the values change in the window. If not then you have the wrong ids set.
Endprodukt:
Tried another fresh install and now it TS2 says "runtime error: 76, cannot find path"?
I'm using 2 aimtraks.
yakk11:
--- Quote from: Endprodukt on March 02, 2013, 10:49:18 am ---TS2 doesn't work for me in M2.
I am having the same problem with my AIMTRAKs. I was playing yesterday morning before installing TS2. I haven't touched the nvram files. Kind of confused on the device ID thing? Thanks for all of your hard work!
UPDATE: OK, fresh install. Now I don't have control at all. I noticed raw input is set to 1. This is tricky stuff so I may just wait until a tutorial comes out or something.
Endprodukt:
Okay... it's still giving me the Cannot find path thing...
But I can confirm that it's not the calibration. Even though TS2 wont install until the end now, the guns will still register in M2. Still only in diagonals... I couldn't even calibrate ingame because the guns only move in diagonals.
It also seems like sometimes the game would register triggering, sometimes not. Right now hotd doesn't want me to shoot but it's working in VCOP.
EDIT: I checked TS2's icon and both guns are registered correctly.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
