Author Topic: Hinge advice please  (Read 7404 times)
monkeychunkuk
Hinge advice please
« on: January 31, 2013, 04:38:54 pm »
Hi can someone tell me what hinge i need to fit on my cabinet door any pictures on how to fit them would be handy aswell
Many thanks
Steve
The direction i want it open
What it looks like without the door
mameshane
  • Last login:November 07, 2022, 05:12:38 pm
Hinge advice please
« Reply #1 on: January 31, 2013, 05:43:30 pm »
Many thanks
Steve
hey monkeychunk :)
I used these on my cab
http://www.arcadeworx.com.au/index.php?route=product/product&path=43&product_id=72
mameshane
Hinge advice please
« Reply #2 on: January 31, 2013, 05:44:20 pm »
Many thanks
Steve
hey monkeychunk :)
I used these on my cab. just a piano hinge. I can take some photos of the hinge and lock after work if u want.
  • Last login:Today at 04:20:03 pm
Re: Hinge advice please
« Reply #3 on: January 31, 2013, 08:17:45 pm »
Inset (pocket?) hinges might be what you want.
Mcseforsale used them here for his CP. (Pics and video at link)
They were originally designed for use with cabinet doors like yours IIRC.
monkeychunkuk
Hinge advice please
« Reply #4 on: February 01, 2013, 03:22:49 am »
Many thanks
Steve
hey monkeychunk :)
Please post a picture not sure how that would work?
Also the cabinet style hinge is gor when the door hangs over the boxing/side panels my door sits back in between the two sides
Thanks for the replies
stripe4
  • Last login:January 05, 2025, 04:19:54 pm
    • forum.arcadecontrols.com/index.php/topic,129541.0.html
« Reply #5 on: February 01, 2013, 07:19:44 am »
As PL1 mentions, you're looking for something best described with keywords "inset hinges":
http://www.brassware.co.uk/FTD-Concealed-Blum-Style-Kitchen-Cabinet-Hinge-With-Built-In-Soft-Close-For-Inset-Doors/pid-20271
The typical euro hinges will require you to screw a piece of wood between the cabinet side and the hinge.
« Last Edit: February 01, 2013, 07:25:50 am by stripe4 »
Woodshop Flunky
« Reply #6 on: February 01, 2013, 10:55:53 am »
As mentioned above, full inset hinges is what you're looking for.
I used them on my son's cab...
I don't have a photo of the hinges installed, but I drew up what I did.  The hinges should be further apart... but this is just an illustration:
These were scary for me the first time I did them... not so much now. :)
The hinge manufacturer will provide an installation sheet (may have to download it).  Also, you can get these at any woodworking store.  The staff can "usually" give you pointers.
Woodshop Flunky
« Reply #7 on: February 01, 2013, 11:10:44 am »
Here's a good illustration of the differences in these hinges.  Woodcraft sells them here: Inset Hinges
dfmaverick
« Reply #8 on: February 01, 2013, 11:30:29 am »
If you check out Knievel's Woody (http://forum.arcadecontrols.com/index.php/topic,55789.40.html), you can see a pic of his application of the hinges.
Knievel talked about the use of them:
"Making the door 1/4" (smaller) than the opening normally works for me, so an 1/8" off either side. You could try trimming less and test fitting it. 1/4" would be the most you'd need to trim off.
If you use the Inset type of European hinge you don't need any sort of frame. The hinge mounts directly to the the side of the cabinet."
yaksplat
    • Random Projects
« Reply #9 on: February 01, 2013, 11:45:15 am »
+1
I've used them on 3 cabinets now for front and back doors, and 4 control panels.  They work great.  Just make sure that you get a 1-3/8" forstner bit.
http://yaksplat.wordpress.com
monkeychunkuk
Hinge advice please
« Reply #10 on: February 01, 2013, 12:18:02 pm »
Thanks for the advice this what i went with
