Poll
What version of PGA do you currently own?
PGA GOLF
7 (4.3%)
CHAMPIONSHIP I
6 (3.7%)
CHAMPIONSHIP II
3 (1.8%)
CHAMPIONSHIP III
20 (12.2%)
CHALLENGE
31 (18.9%)
TEAM CHALLENGE
54 (32.9%)
TEAM CHALLENGE w/ ALL ACCESS
28 (17.1%)
I DON'T OWN A VERSION BUT WOULD LIKE TO!
15 (9.1%)
Total Members Voted: 164
Author Topic: PGA Tour Golf by Global VR & EA Sports Owners Thread  (Read 550091 times)
mx5xm
  • Last login:May 19, 2024, 10:49:58 pm
Re: PGA Tour Golf by Global VR & EA Sports Owners Thread
« Reply #2760 on: June 28, 2023, 12:29:00 pm »
« Last Edit: April 16, 2024, 01:27:14 pm by mx5xm »
drummer_god
  • Last login:Today at 07:17:47 am
« Reply #2761 on: July 02, 2023, 01:30:11 pm »
Did you install the correct sound driver for that Dell dimension?
Thunderspy0712
  • Last login:March 14, 2024, 06:59:20 pm
« Reply #2762 on: October 04, 2023, 01:59:40 pm »
do you guys have Championship Editon I ISO
mrsyfy
  • Last login:March 11, 2024, 10:48:11 am
« Reply #2763 on: January 11, 2024, 05:45:41 pm »
I am working on one just like this one. No video, from either the vga or the svga ports. Trying to see what is needed to replace and reboot the cpu. Any help will be welcomed.
Thank you
Mrsyfy
  • Last login:Yesterday at 06:47:36 pm
« Reply #2764 on: January 11, 2024, 07:07:42 pm »
Thank you
Mrsyfy
it it appears to be working (fans spinning lights on but no video.) it could be bad ram or bad CPU or bad videocard.
check and see if the computer speaker is plugged in... usually it will beep a code at you to let you know what the deal is if its the cpu or ram... but not always.
if the speaker is connected and not making any beeps at you, suspect the CPU. try removing and reinserting it. remove and reinsert the video card. AGP is notorious for bad connections.
check you motherboard for swollen bulged or leaky capacitors. google "bad caps" and see what they look like... you may have a half dozen that need replacing.
otherwise start shopping for a used dell... there is a side thread about swapping to a dell computer in this thread here a few years back.
Nudge55
  • Last login:February 25, 2024, 04:43:27 am
« Reply #2765 on: February 04, 2024, 05:24:38 am »
Hi guys working on restoring my team challenge. I purchased a gx280 the only issue I’m running into is it’s a SFF and has only one IDE port so cd rom is ide but HDD isn’t. Is there a solution to this at all? From what I’ve read I need both cd rom and HDD to be ide and I know very little about ide connections so any help I would appreciate so much.
mx5xm
« Reply #2766 on: March 03, 2024, 03:43:29 pm »
« Last Edit: April 16, 2024, 01:26:31 pm by mx5xm »
Thunderspy0712
« Reply #2767 on: March 14, 2024, 02:11:40 am »
I Got Problem with Championship I
nipsmg
  • Last login:Today at 08:09:59 am
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2768 on: March 14, 2024, 08:49:37 am »
My team challenge PC died long ago. I've been digging around with a Dell replacement PC and having very little luck with the imaged hard drive I dropped in.
I was wondering three things that might help.
1 - is there any automatic driver downloader software for Windows XP? I've got some miscellaneous drivers I can't seem to find and I think they are the reason my PC will boot and load PGA tour, but button presses don't work.
Not that I'm aware of.  Are you in the facebook group?  That's your best and probably only resource for the necessary drivers.
2 - if I can't get things to work, can I update the PC to windows 7, then still let PGA tour auto-boot and such?
No.  This definitely does not work.  I don't believe you can upgrade from XPEmbedded to 7.
3 - if nothing else, could I do a fresh clean install of XP or Windows 7 and install the PGA tour software separately?
No. Doesn't work that way.  there's too many dependencies.  Again, there's a very, very manual way to make this work but it's not 100% stable and it's like a 100 step process.
mx5xm
« Reply #2769 on: April 16, 2024, 01:24:41 pm »
Does anyone have the team challenge ISOs they can share? I thought I did but I have the regular challenge. I'll share those if anyone needs them.
Also, has anyone been able to install XP SP1 on top of XP embedded? My setup has USB 2.0 and I can't get the sound to work because I need an updated chipset that requires SP1. The SP1 installer gives me some sort of certificate error when I try to run it.
« Last Edit: May 07, 2024, 10:46:15 pm by mx5xm »
picklert
  • Last login:May 16, 2024, 01:40:33 pm
« Reply #2770 on: April 27, 2024, 10:37:52 am »
I came across the original EA Sports PGA golf. Unit is good except the hard drive is bad. Is there a way to get the ISO of the hard drive? No disk left in unit. I have dongle original DFI computer. Really like to get this cabinet up and running for the family. Thanks for any help.
mx5xm
« Reply #2771 on: May 07, 2024, 10:44:12 pm »
Someone on here can share the links for the restore discs and latest software too. I am here for the same request. :)
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2772 on: May 08, 2024, 08:25:06 am »
Join the Facebook group-- I'm certain it's mentioned in this thread.  That's where support is and where you can get literally any help you could possibly need to get it up and running.
vespertillio
  • Last login:May 15, 2024, 12:32:00 pm
« Reply #2773 on: May 08, 2024, 12:37:45 pm »
I put in a request to join as well. Wouldn't mind getting mine up to speed.
Sent from my SM-S908U using Tapatalk
--Don't count your weasles until they pop, dink!--
--I don't really like my friends.
Yeah, I don't really like your friends either.--
-Lee Harvey Oswald was not a male model... You're ---gosh-darn--- right he wasn't, but those two lookers who capped Kennedy from the grassy knoll sure as ---steaming pile of meadow muffin--- were.-
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2774 on: May 08, 2024, 07:00:49 pm »
Yeah, get it online joined and play tournaments with like.. 70 new courses. :)
