Author Topic: Rampage, tapper, xenophob... 30Hz! ?  (Read 4486 times)
Endprodukt
  • Last login:January 31, 2026, 03:39:07 pm
« on: December 04, 2012, 07:04:29 pm »
Is this true? Native resolution 512x480 @ 30Hz for those games. What kind of monitor can do that? GM creates interlaced modes and it doesn't look too good. What would you suggest?
Gesendet von meinem HTC Desire HD A9191 mit Tapatalk 2
  • Last login:Today at 03:39:39 am
Re: Rampage, tapper, xenophob... 30Hz! ?
« Reply #1 on: December 05, 2012, 07:59:25 am »
Some Bally Midway games originally used interlaced modes to allow high resolution sprites over low resolution backgrounds. An interlaced mode of 60 Hz only updates a full frame only at a 30 Hz rate, that's why MAME reports that speed and it's perfectly correct.
As a fact GM (just because it can!) renders these game as progressive when you use a 31 KHz capable monitor, but this is plain wrong in terms of accuracy.
Endprodukt
« Reply #2 on: December 05, 2012, 08:02:45 am »
So what would be accurate on a 15khz monitor? Interlaced as it is?
« Reply #3 on: December 05, 2012, 08:07:19 am »
Obviously.
Endprodukt
« Reply #4 on: December 05, 2012, 08:09:41 am »
Does that mean the original games had flickering?
« Reply #5 on: December 05, 2012, 08:15:52 am »
Sure, as your TV did. Whether flicker was *so bad* on those old CRTs, that's a different story.
Endprodukt
« Reply #6 on: December 05, 2012, 08:21:29 am »
Hm, pretty bad on my Polo I think.
« Reply #7 on: December 05, 2012, 08:51:52 am »
New monitors with thinner scanlines have better definition but for the same reason, interlaced modes flicker more. Some old monitors just don't display good interlaced modes, it's like if both fields didn't fit properly. Some users also reported the Radeon X series to provide nicer looking interlaced modes than the HD 4xxx cards. Finally, you can reduce the apparent flicker quite a lot, at the cost of loosing sharpness, by using the -filter option for these games.
