Main > Project Announcements
A DIY push-pull spinner
PL1:
Looks like an interesting design, but my main points of concern are these:
1. Friction against the microswitch nub while pushing/pulling and turning at the same time causing wear. (plastic vs. metal)
2. The encoder wheel 4mm vertical travel range (+2mm to -2mm) may cause problems like hitting the sensor or with the sensor/wheel distance unless the sensor can shift up and down with the encoder wheel and shaft.
Mysterioii:
--- Quote from: PL1 on October 16, 2012, 01:32:58 pm ---Looks like an interesting design, but my main points of concern are these:
Use the microswitches that have the roller on the actuating lever... example:
http://omvol.en.alibaba.com/product/436002015-213182615/Short_Hinge_Cross_Roller_Lever_Micro_Switch.html
PL1:
--- Quote from: Mysterioii on October 16, 2012, 02:03:23 pm ---
Which increases the actuation distance ==> more of point #2. :dunno
If the roller was over the nub instead of at the end of an arm, it would solve the increased actuation distance issue. Some arms are removable -- might be able to cut/re-bend it shorter.
Radioshack has these.
Mysterioii:
Yeah you just bend the lever arm, put it on pretty much any level you want.
PL1:
--- Quote from: Mysterioii on October 16, 2012, 03:06:14 pm ---Yeah you just bend the lever arm, put it on pretty much any level you want.
The problem isn't the height, it's the length. Shorter arm requires less vertical travel (blue) than the longer arm. (red)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
