Main > Project Announcements
Banana Royale (Pac Man Battle Royale Redesign Contest)
Pages: << < (43/62) > >>
Sjaak:
--- Quote from: Le Chuck on March 14, 2014, 06:49:52 pm ---Sjaak - are you going to keep on developing the other version that uses the simple sprite sheet?
No, that thing was a nightmare to support. The code was full of x, y coordinates that changed every time the layout changed.
There is however support for texturepacker built in, so you can create a sprite sheet and atlas using spritepacker and use that in the game. This also speeds up loading of the game. More on that later...
I'll take a look at the sprite rotation. I can probably make that configurable, so it doesn't interfere with the pac man sprites.
Le Chuck:
--- Quote from: Sjaak on March 15, 2014, 04:45:35 am ---
Word to all  :cheers:  Look forward to future updates.  I'll fiddle with the sprite set some more later, I'll move onto other things for a few weeks for now or until your next feature rich version  :applaud:
Syco54645:
Where are the pacman sprites? I am guessing that people are making those on their own. I looked through the thread and was unable to find them. About to go try this out. Keep up the great work!
Syco54645:
double post deleted/
Sjaak:
--- Quote from: Syco54645 on April 19, 2014, 11:00:20 pm ---Where are the pacman sprites? I am guessing that people are making those on their own. I looked through the thread and was unable to find them. About to go try this out. Keep up the great work!
You are correct, there are no pac man sprites in this thread. I think the reason is obvious. Creating the sprites isn't too much work and you can also run the game with the default sprites.
Go to full version
