Main > Project Announcements
Banana Royale (Pac Man Battle Royale Redesign Contest)
Sjaak:
--- Quote from: dgame on January 13, 2014, 09:45:51 am ---Anyone run this on Windows XP? It does not start for me, something about a missing library. Fix-it-Felix works and I think they use the same libraries?
Works fine on Win 7.
Do you know which library is missing? And you're right about Fif, they should both use the same libraries.
dgame:
No, I don't know which library it can't find. I can get it to throw the error if I right-click and run as myself. It just says a generic message like 'required library missing'
Can you make a debug version that says what is missing in a log file or something? Thanks.
Sjaak:
--- Quote from: dgame on January 13, 2014, 09:53:32 am ---Can you make a debug version that says what is missing in a log file or something? Thanks.
If a library is missing the program can't start. And if the program can't start, it can't write to a log file. Maybe a screenshot of the message? And if you start Fif in the same way, you get no message?
thatpurplestuff:
--- Quote from: Le Chuck on January 13, 2014, 08:06:05 am ---In fact being able to select cocktail or upright in the menu would be awesome and then the game auto adjusts.
This would be amazing.
Also love the idea of making sprites for every direction.
dgame:
--- Quote from: Sjaak on January 13, 2014, 10:00:30 am ---
Yeah, Fif stars right up on the same system without error. I even reinstalled the libraries. I will try somethings tonight and see if I can find any clues. I can post a screenshot later. Thanks.
