Main > Monitor/Video Forum
Toshiba crt tv question
tony.silveira:
--- Quote from: kenshen on August 17, 2012, 07:55:03 pm ---Got it wheres a good place to start?
search in the monitor forum for "discharging tube", you should come up with some walk thrus. PLEASE, proceed with CAUTION and AT YOUR OWN RISK.
did you plan on using the tv in the arcade machine as is, meaning, you don't plan on removing it from its case?
kenshen:
yes but if i have to remove it's case i will you see I'm building a modified mortal kombat cab that's 26 in wide because the tv is 25 1/2 inches wide but if decaseing it will help so be it...
kenshen:
BUMP
tony.silveira:
decasing it is up to you. if it will fit in your cab with the case, go for it. tv's can be a complicated to dacase and to mount into a machine; the boards aren't in a neat metal chasis like arcade monitors.
but to get to the power button, you will need to open it up.
kenshen:
ok sweet thanks
Navigation
[0] Message Index
[*] Previous page
Go to full version
