Author Topic: Question on reading Jaokbud arcade cabinet plans  (Read 5177 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: May 15, 2012, 10:11:24 am »
Can someone tell me what R16.14" means?  I've never really done angle cuts at all and was hoping someone here could enlighten me a little bit.
yaksplat
    • Random Projects
Re: Question on reading Jaokbud arcade cabinet plans
« Reply #1 on: May 15, 2012, 11:03:34 am »
R usually refers to a radius.  That seems quite large though for a cab.
link?
http://yaksplat.wordpress.com
  • Last login:February 28, 2026, 04:55:22 pm
« Reply #2 on: May 15, 2012, 12:36:23 pm »
You have to be careful with the Jakobud plans, FYI.  They aren't exactly right.
iscariot
« Reply #3 on: May 15, 2012, 05:05:04 pm »
That's what I figured....I was looking at a good one or two to build...figured I could use those but I have no idea how to draw a radius like that on the plywood.
iscariot
« Reply #4 on: May 15, 2012, 05:07:56 pm »
OBTW, I was looking at the MS pacman cabinet
« Reply #5 on: May 15, 2012, 05:15:13 pm »
Pencil, nail, & a piece of string
elkameleon
« Reply #6 on: May 15, 2012, 05:24:09 pm »
I second this. Unless you have some background in drafting, or have the help of software, they kinda come out funny.
iscariot
« Reply #7 on: May 17, 2012, 10:10:11 am »
What do you mean pencil, nail, piece of string?
« Reply #8 on: May 17, 2012, 10:13:34 am »
Say you need a 12" radius marked out.  Take a nail, tap it in at the center of the arc, leave some of the nail sticking up.  Tie a piece of string to the nail.  Measure out 12" on the string, tie a pencil to the string, pull the string tight, and you can draw a curve that way.
You could also do the same thing with a ruler or yardstick if you don't mind poking holes in it.
Woodshop Flunky
« Reply #9 on: May 23, 2012, 10:49:06 pm »
... I have no idea how to draw a radius like that on the plywood.
A beam compass is a good thing to have.  A string and a nail will certainly work, but I've always had trouble getting an exact radius after trying to tie the pencil to the nail.  With a beam compass I'm able to get exactly what I want... down to my ability to read a scale.
My cab had several large curves, R7 7/8", R10", and R40 1/4"... layout was very easy with the beam compass.
