Main > Main Forum
Build an OND designed cab 'Metropolis'
ZTylerDurden717:
Thanks so much for confirming! I'll make the radius slightly larger.
I'm definitely going to use a template for the CP. As for the corners for these side panels-- I can pull it off free hand. As long as I stay just outside the pencil line I feel confident doing it. :cheers:
Also, I'm from Miami. I was instantly sold on your art deco design since that's our staple architecture style at the beach.
ZTylerDurden717:
hey vaderag,
Hope you're well!
How did you end up mounting the marquee art? If you're using purple t-molding on the marquee wood panels, where are the marquee retainers?
Would really like to know what you did there.
edit: I researched the forums and noticed you considered making small grooves but since the marquee panels aren't "flat" it wasn't possible. If you used tape/glue I'll definitely consider it too. If you could be detailed in terms of how you applied the tape/glue with the t-molding I'll give it a go. The t-molding color is a really nice touch and I wouldn't want to use a plain bracket.
vaderag:
Hi mate,
I tried a BUNCH of different methods - bending Aluminium, clips etc. In the end used Tape - 50mm Black Electrical Tape in fact.
The bottom of the marquee sits in a slot on the flat piece, it's a little close as there is a slot on the top and a slot for the t-mould on the front
Then the top of the marquee is taped to the top of the unit.
I then cut the back off some t-mould and glue gunned it straight as possible on top of the tape
Hope that helps!
ZTylerDurden717:
Thanks for coming back! I see where you're going but I don't understand how you have the marquee leaning forward if the groove on the bottom marquee panel would make it lean back since it's downward angled. Attached is a quick visual of what I mean. We're looking at the cabinet from the profile.
Is it that you have the marquee in the groove pivoted at a 45 degree leaning forward ie not fully in the slot (not seated at 90 degrees)?
Sorry for the additional questions, I just really want to get this right before assembly:
1) Is the groove cut inward a few mm from the edge (like the attached graphic) or is it cut right at the beginning where the t-molding would push on it? Based on your photos looks like it's a rebate right "behind" the edge
2) No grooves/rebates on the top panel, correct? Just t-molding.
Thanks again! I really appreciate it.
vaderag:
Mine doesn't look like that - it has a flat bit at the bottom and it just rests against the top...
