Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
AMDman13:
Man I am sorry for the questions. I hope someone here can answer this one. It seems so simple, but I can't find the answer anywhere. :-[
I don't understand where in Mame.ini to change the following settings:
resolution 2560x0
cleanstretch 2
I see cleanstretch as a setting that is under Core Switchres. Currently it is set to 0.
Do I simply add these lines somewhere? If so which heading?
AMDman13:
Totally confused
Calamity:
--- Quote from: AMDman13 on October 15, 2014, 12:01:29 pm ---I see cleanstretch as a setting that is under Core Switchres. Currently it is set to 0.
Simply edit the value that is "0" by default in mame.ini with a "2". The -resolution option is set as "resolution auto" by default, just search it through the file and replace "auto" with "2560x0".
AMDman13:
Thanks Calamity!
For the resolution it is located under
OSD PER-WINDOW VIDEO OPTIONS?
8BitMonk:
Should be the only part of the mame.ini that says 'resolution auto', search for 'resolution auto'.
