Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Pages: << < (29/42) > >>
Calamity:
Also, apply the minimum 50 Hz limit, not related with your posted results but it should be required to avoid your previous issues with starwars:
crt_range0    15625-15900, 50-59.96, 7.800, 4.700, 10.600, 0.190, 0.191, 1.018, 0, 0, 192, 248, 448, 496
crt_range1    15625-15900, 59.98-80, 3.000, 4.700, 7.700, 0.190, 0.191, 1.018, 0, 0, 192, 248, 448, 496
crt_range2    16000-17200, 58-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 249, 256, 498, 512
crt_range3    18300-18800, 50-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 257, 280, 514, 560
crt_range4    18800-19000, 50-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 281, 320, 0, 0
crt_range5    24000-29000, 50-80, 2.020, 2.820, 6.460, 0.890, 0.148, 1.373, 0, 0, 384, 400, 0, 0
crt_range6    30000-34000, 50-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 448, 496, 0, 0
crt_range7    34001-38000, 50-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 512, 600, 0, 0
8BitMonk:
Hey Delusional, were you able to test again with these updated values? Mind sharing your .ini files? Happy to run with testing if still needed, I have the same setup.
Calamity:
Hi 8BitMonk,
If you have the same monitor, I'd be great if you could test the settings in my last post: http://forum.arcadecontrols.com/index.php/topic,117489.msg1445684.html#msg1445684
Just put those in their corresponding place in mame.ini, and set the monitor option as "custom".
8BitMonk:
Hi Calamity, thanks for the response
I tested these settings last night with a bunch of games, all of the ones Delusional listed as well as some I took from the 'Games with ISSUES' thread. Overall the results were great with only a handful of remaining issues. Most of the game speed problems were gone, mk still has an issue with the picture bowing as RetroACTIVE reported.
How would you prefer I report back for troubleshooting, text grid like Delusional, rom.txt files, screenshots?
Can someone tell me how people are taking mame in-game screenshots that are full screen and include the mame osd menu. f12 does just the game and no menu, print screen doesn't seem to work at these odd resolutions.
8BitMonk:
I was able to test about 60 games with the most recent settings posted by Calamity. I'm keeping the results in a shared Google spreadsheet, link below.
--> GROOVYMAME BETSON-KORTEK TEST RESULTS GOOGLE SPREADSHEET CLICK HERE<--
Green=Good  Yellow=Minor Problems  Red=Major Problems
Next I'll try to recreate the display issues in ArcadeOSD, adjust for them and report better values back as was suggested to RetroACTIVE. If anyone has any other suggestions to fix please let me know. Hopefully with a little trial and error we can get them all ironed out.
Go to full version
