Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
RetroACTIVE:
--- Quote from: DeLuSioNal29 on April 09, 2014, 10:09:55 pm ---Retroactive, would you mind sharing your current setup? I'd like to mimic what you have. I can set up a Dropbox folder if you need to drop any files in.
Let me know...
DeLuSioNaL29
I've backed it up because I tore down my setup... I do have it all. I'll fire it up and pull it for you.
DeLuSioNal29:
Any updates Retro? I'm a bit more familiar now that I've beta tested the Win 7 emu driver.
Let me know and thanks in advance!
DeLuSioNaL29
Calamity:
Hi DeLuSioNal29,
This is an attempt to port the old monitor_specs lines to the new format used by GM. Please test so we can eventually add this monitor preset to GM:
crt_range0 15625-15900, 40-59.96, 7.800, 4.700, 10.600, 0.190, 0.191, 1.018, 0, 0, 192, 248, 448, 496
crt_range1 15625-15900, 59.98-80, 3.000, 4.700, 7.700, 0.190, 0.191, 1.018, 0, 0, 192, 248, 448, 496
crt_range2 16000-17200, 58-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 249, 256, 498, 512
crt_range3 18300-18800, 40-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 257, 280, 514, 560
crt_range4 18800-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 281, 320, 0, 0
crt_range5 24000-29000, 40-80, 2.020, 2.820, 6.460, 0.890, 0.148, 1.373, 0, 0, 384, 400, 768, 800
crt_range6 30000-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 448, 496, 0, 0
crt_range7 34001-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 512, 600, 0, 0
DeLuSioNal29:
Hi Calamity,
I did some testing over the last couple of days with some random games. I wanted to reply only when I had a thorough answer. I tried two different setting in the custom section of mame.ini. The column GM (Betson Test) is the one mentioned here. The column GM (D9800 50Hz custom) is the one mentioned here.
Game | Native MAME Res | GM (Betson Test) | F11 Game speed | GM (D9800 50Hz custom) | F11 Game speedAero Fighters320x2242560x320100%2560x240100%Bomb Jack256x2242560x256100%2560x256100%Caveman Ninja256x2402560x240100%2560x240100%Centipede/Millipede256x2402560x80084%2560x464100%Circus Charlie256x2242560x256100%2560x256100%Do Don Pachi320x2402560x80068%2560x464100%Do Don Pachi Dai-Ou-Jou v101448x2242560x448100%2560x448100%Mad Planets256x2402560x80080%2560x464100%Q*Bert256x2402560x80080%2560x464100%Raiden Fighters320x2402560x80070%2560x464100%Raiden Fighters 2320x2402560x80070%2560x464100%Raiden Fighters Jet320x2402560x80070%2560x464100%Rampage512x4802560x800100%2560x464100%Satan's Hollow512x4802560x80080%2560x464100%Space Invaders '95320x2242560x320100%2560x320100%Super Space Invaders320x2242560x320100%2560x320100%Spy Hunter480x4802560x80080%2560x464100%Tapper512x4802560x800100%2560x464100%Toki256x2242560x240100%2560x240100%Zookeeper256x2562560x264100%2560x256100%
The GM resolution that were at 2560x800 ran slower. Not sure why GM chose that resolutions. With the exception of Rampage and Tapper. :dunno
As an experiment, I removed the Super Res of 2560x800 from the ReslList.txt file and rebooted. GM then chose 2560x768 for those games. (So I switched it back for now until we troubleshoot).
DeLuSioNaL29
Calamity:
Hi DeLuSioNal29, thanks for your report. Simply replace this line:
crt_range5 24000-29000, 40-80, 2.020, 2.820, 6.460, 0.890, 0.148, 1.373, 0, 0, 384, 400, 0, 0
