Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Pages: << < (24/42) > >>
milhouse:
--- Quote from: Calamity on April 08, 2012, 02:47:16 pm ---
--- Quote from: RetroACTIVE on April 04, 2012, 07:21:44 pm ---Hey Cal... I've been busy and haven't had a chance to get back to this... Did you get a chance to look at my attachments?
Hi RetroACTIVE, yes I looked at your results. My conclusion is that the monitor_specs are already fine, but I need to fix GroovyMAME's modeline scoring system. If you have a look at your log, the right modeline is actually calculated in range 2, but GM is still picking the one from range 1 because it doesn't notice the second one is any better. That needs to get fixed.
Any idea if this is the same issue with Tempest and other 640x480 games?
Thanks.
Calamity:
--- Quote from: milhouse on April 09, 2012, 02:38:23 pm ---Any idea if this is the same issue with Tempest and other 640x480 games?
No, it's a completely unrelated issue.
RetroACTIVE:
--- Quote from: RetroACTIVE on April 08, 2012, 04:54:14 pm ---
Ok cool thanks :cheers:
I'm picking this back up... I need to update my copy of groovymame and get my brain around where I left off.
RetroACTIVE:
Allrighty... downloaded latest copy of VMMaker and groovy...
Re-ran my tests with new my old monitor settings (previous tests).  Created a new mame.ini and the good news is, it is behaving exactly the same.
tempest is still a blank screen and toki, snowbros, bublblobl (< 60 Hz) still have the geometry issue (goes beyond the left and right edges) games like goldenaxe (60Hz) are fine.
Calamity:
That's good RetroACTIVE,
I'm *right now* in the process of coding the new patch that should fix, among other things, the issue mentioned here:
--- Quote ---Hi RetroACTIVE, yes I looked at your results. My conclusion is that the monitor_specs are already fine, but I need to fix GroovyMAME's modeline scoring system. If you have a look at your log, the right modeline is actually calculated in range 2, but GM is still picking the one from range 1 because it doesn't notice the second one is any better. That needs to get fixed.
It will take me one ore two weeks at least, please be patient  :)
Go to full version
