Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
RetroACTIVE:
I had a chance to try the updated monitor_specs... goldnaxe is still the same.
I've attached a log for that and ModeList.txt and Modeline.txt files.
milhouse:
--- Quote from: Calamity on January 23, 2012, 01:56:23 pm ---Just post here a log of a random game that produces a blank screen, by doing this:
groovymame.exe romname -v -md 4 >romname.txt
I'll have a look at it before we go any further. When you have your system up and running we'll start with the monitor specs.
I posted in another thread and just saw this. Since this is the monitor I have, I figured its better posted here...
The issue is Tempest. ATI HD4650.
RetroACTIVE:
Hey Cal... I've been busy and haven't had a chance to get back to this... Did you get a chance to look at my attachments?
Calamity:
--- Quote from: RetroACTIVE on April 04, 2012, 07:21:44 pm ---Hey Cal... I've been busy and haven't had a chance to get back to this... Did you get a chance to look at my attachments?
Hi RetroACTIVE, yes I looked at your results. My conclusion is that the monitor_specs are already fine, but I need to fix GroovyMAME's modeline scoring system. If you have a look at your log, the right modeline is actually calculated in range 2, but GM is still picking the one from range 1 because it doesn't notice the second one is any better. That needs to get fixed.
RetroACTIVE:
--- Quote from: Calamity on April 08, 2012, 02:47:16 pm ---
Ok cool thanks :cheers:
