Main > Project Announcements
new idea! home arcade system build
Pages: << < (2/5) > >>
BobA:
I just picked up an Intel D525MW ITX motherboard.  It is fairly new and runs a dual core atom at 1.8 Ghz.  My biggest interest was that it is a fanless board with very low power consumption. It is a bit odd as it runs laptop sodimm memory but the 2 GB DDR3 that I picked up was only $24 so it is not much more expensive then regular memory. It also says that it runs a more advanced onboard video proc.  It was cheap so I got one to test how mame and other emulators run on it.   Just hooked it up yesterday so will be a few days before I can say how things go.
yotsuya:
Funny, I just picked up a D510 itx for jukebox purposes. They are pretty cheap.
Necro:
Wait - 'found in the attic'.  Where do you live and who do you live with that you just find stuff like that in your attic and aren't aware it's up there?  :)
Mikeosoft:
--- Quote ---1) is there enough clearance in there for a netbook? Looks pretty tight.
i believe there is enough clearance for a mini itx, definitley enough for my msi netbook bottom without the lcd connected. that's assuming i leave the same butons in there which i am not going to do.
--- Quote ---2) can you give it enough airflow
i believe a fanless system wouldn't need cooling beyond open space, for example my atom netbook runs cool with osx hackintosh 10.6.2 overclocked with just a stock crappy heatsink and the fan removed.  I believe even in the most powerful scenario, an i3 intel processor with a stock heatsink, which is overkill in my mind, i'd probably get away with just removing the plastic case on the unit where the controller cords were meant to fit, or i could just cut a circle in the side and put a ball bearing coolermaster fan on the side blowing air in at low rpm towards the processor heatsink.
--- Quote ---3) how are you going to power it? or turn it on?
standard mobo's have a pin junction for connectors to fit and a diagram. it's just a matter of connecting momentary switch to the PWR on/off to get the mobo to turn on and off.  I plan on using a happ button to make the connection here, placing it on the side of the unit hidden from view.  worst case i'll wire it to a small led lit 24mm button i have lying around from a candy cab cyberlead i finished off and didn't use.
--- Quote ---I've used a mini-ITX board which was an Intel Atom 330 based system. It has on board graphics and the CPU runs at 1.6 GHz. Runs all the classics great but will struggle with some of the more modern stuff. I just used it in my Defender/Stargate bartop and it's great. It also handles scanlines fine and the game still runs at 100%. You won't get Hyperspin working at full potential with this board however. Might be better with Mala or you maybe could still use Hyperspin but with lots of graphical features turned off.
sounds just a tad more powerful than my msi wind (atom n270) netbook running hackintosh'd osx.  This little bastid got me through east africa and kilimanjaro in one piece.  Saved my life more than once... best investment I ever made   :cheers:
i read some specs requirements on the hyperspin homepage and you're spot on. I think since hyperspin is coded to primarily work with flash ( a very poorly optimized code from adobe) I'm going to have to turn off most effects and intro video.  No problem though, if the heat requirement means i need to go atom based than so be it.  But i think the newer ION system not to mention AMD offerings are capable of displaying 1080p flash content without hiccup.  If this is so i should see improvement.   I need to do more research on newegg and anandtech.com i'm very out of the loop with sff and low voltage offerings these days, crazy market out there.
--- Quote ---I just picked up an Intel D525MW ITX motherboard.  It is fairly new and runs a dual core atom at 1.8 Ghz.  My biggest interest was that it is a fanless board with very low power consumption. It is a bit odd as it runs laptop sodimm memory but the 2 GB DDR3 that I picked up was only $24 so it is not much more expensive then regular memory. It also says that it runs a more advanced onboard video proc.  It was cheap so I got one to test how mame and other emulators run on it.   Just hooked it up yesterday so will be a few days before I can say how things go.
I have a microcenter about 20 minute drive from me in patterson nj, and i can go grab equipment pretty quickly.  I will look into this mobo, and as far as i know they do price match newegg which is always a plus.  They always have good deals on laptop ram i've noticed.  Awesome store btw.
Please let me know how this mobo/processor/ram combo works out for you, what front end are you running and what emulation are you going for?  I'm thinking my most played mame catalog is going to be Neo-geo and cps2 era hardware.  This seems like something a 1.6ghz atom processor can handle, however, the more recent builds of mame are resource hogs I've noticed and I'd like to maybe try some newer shooters if possible, maybe even SFIV if i go with an i3 and a decent onbord graphics i might be able to pull it off.
--- Quote ---Funny, I just picked up a D510 itx for jukebox purposes. They are pretty cheap.
after i post this i will checkout slickdeals.net and newegg to see the price on this mobo and ram options
I noticed that many pico itx mobos have external psu units with a plug.  This would be cool i need to look into this.
--- Quote ---Wait - 'found in the attic'.  Where do you live and who do you live with that you just find stuff like that in your attic and aren't aware it's up there?
Well I was an avid video game collector back in my youth and sometime in 2003 or 2002 I went to an eb games that was closing (due to gamestop buyout) and picked up this pelican unit for dirt cheap.  At the time i remember the news just broke like two days before that mame was ported to xbox 1 once the system was hacked by bunny. Ah the classic good old days of utilizing one's purchased goods in ways for which the manufacturer never intended. Ah what a time! ;D
I went off to college in 2005 and my parents moved to a new house in 2007 while I was living in Boston.  I came back to a new house and all my video games and rare systems were missing.  I cried in my sleep for weeks, drank a ton, and never forgave my parents to this day. Just kidding, I still need to find all my stuff they moved, but no hard feelings because I wasn't there to help them move (horrible son... stuck with finals in boston).
Donkbaca:
Probably better to have a small fan blowing out instead of in, you want to blow all the heat out of the box.  When I asked about power. I meant is a power supply going to be in the box? Or are you using an external power supply?
Go to full version
