Main > Project Announcements
new idea! home arcade system build
Pages: << < (5/5)
BobA:
Already tried it.  No go needs alot more HP.  That is why I am using Maximus arcade.  It would probably need one of the newer itx with dual core AMD and graphics.
Mikeosoft:
damn it hyperspin!!! ARRRGGGGHHHH!
I've been checking out this board:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128468&Tpk=GA-E350N-USB3
apparently the benchmarks are good!
"StreetFighter IV Benchmark
1280 X 720 => 30.07 FPS"
crazy, if this cant run hyperspinfe intro vid I give up lol
150 dollars doesnt seem bad.  Granted it's got a fan, and supposedly its high pitched, and I'm assuming i'd need to definitely run another fan with a hole on the side of the case... What do you guys think?  Should i hold out or bite the bullet and try this fusion offering?
BobA:
The difference between an intel mini itx and one with a bit more zip is usually only about 50 dollars so if you have hyperspin in you wish list go for it but it will mean more cooling and a more powerful power supply.   It may start to get hard to stuff it all into your CP.
Pages: << < (5/5)
Go to full version
