Main > Project Announcements
Complete redesign due to TV failure
crashwg:
Here's a shot of the two sides held together with a test CP and the chamfer around the monitor. I'm thinking about moving the controls in away from the sides a little bit to make a little more room for the hands but I think it may look a little funny... IDK, I'll probably try it, it's not like I can't whip up another fairly quickly.
crashwg:
--- Quote from: syph007 on July 02, 2011, 08:49:14 pm ---You can buy 1/2 t-molding in black or white, and colors in 5/8 (which trims up real nice to 1/2 inch) if you did want t-molding. I just test fit a piece of 3/4 inch on 1/2 MDF and it timmed up fine too.
I would consider that if this weren't a thrifty build. I'm still trying to work out how to get sideart on the cheap...
Well Fed Games:
--- Quote from: crashwg on July 02, 2011, 10:17:45 pm ---
--- Quote from: thefearsomefearful on July 02, 2011, 10:16:10 pm ---I've collected almost the exact same parts for a similar project.. only mine is the 8-in-1 stick
8-in-1 stick? Tell me more.
http://www.amazon.com/Jakks-Pac-Man-Gold-TV-Game/dp/B000QW6QBY/ref=sr_1_2?s=toys-and-games&ie=UTF8&qid=1309699551&sr=1-2 basically, has Pac-Man, Galaxian, Dig Dug, Rally-X, Bosconian, Super Pac-Man, Pac & Pal, and Pac-Man Plus.
and the VHS?http://www.overstock.com/Electronics/FunTV-Portable-VHS-Player-with-4-inch-LCD-Monitor-Refurbished/583441/product.html thankfully the screen is a separate part of the unit. With A/V Jacks!
Love the cabinet shape!
crashwg:
--- Quote from: thefearsomefearful on July 03, 2011, 09:29:46 am ---
Two questions:
1. What are the controls on the 8-in-1? The one I have has a power switch, a reset switch and a single button. I can't tell from the pictures or descriptions if it has some sort of reset or menu button.
2. Does it save scores? I got one of the Ms. Pac/Galaga/Pole Position/ etc. ones that apparently was released by QVC that saves scores and I like the feature I just don't know how nor want to put in the effort of hooking up the steering for Pole Position...
BobA:
--- Quote from: crashwg on July 02, 2011, 07:32:13 pm ---
--- Quote from: BobA on July 02, 2011, 06:55:43 pm ---Use a round over bit with a radius of 1/2 of your mdf size and ride the bearing on the middle of the MDF.
After I've done one side will the bearing have a large enough place to ride?
Should have the original height in the center if you adjust your roundover bit right. You may need to try on a few scraps to get the hang of it. You can use a smaller radius and just touch it to each side until it looks good to you. You don't need to get a bit with half the radius unless you want to rout a true half circle as your edge. Actually a smaller bit is probably easier to work with as you just touch each edge and it leaves the center of the mdf.
