Main > Project Announcements
MAME Dual Light Gun Shooter in Virtua Cop 2 Cabinet
Pages: << < (2/5) > >>
mike boss:
--- Quote from: 8way on March 07, 2011, 07:58:25 am ---One problem i see, is the specs on that PC are kinda low. You wont be able to run games like Area 51, CarnEvil, Time Crisis. At least not the MAME or PS2 versions. They should be fine on Psx emulator.
I don't play on putting any PS2 emulator on the cabinet. It was however suggested I beef up the CPU. Adding some RAM is something I think I will do for sure, I'll double it.
Donkbaca:
Time crisis doesn't run well in MAME anyway,  I can run Area 51 with the same set up, can't run carnevil though
mike boss:
Modified the layout to reflect "use up & down to select game" & "press player one  to start."
Excellent point was made, I designed the layout knowing how MaLa worked, not thinking that someone else would be stuck! Thanks
mike boss:
Aim Traks came in today !
Still in the process of rounding up all the required files I need for the PC.
I plan on doing that this weekend.
Question, some of the input I got leans towards that PC (specs above) perhaps not having enuff power.
I'm looking to get more RAM to fix that.
Any harm in loading the files getting everything done, installed, tested, configured, then adding the RAM last ?
eds1275:
Nope! Do what you can and then test it out!
Go to full version
