Main > Project Announcements
MAME Dual Light Gun Shooter in Virtua Cop 2 Cabinet
mike boss:
Was able to make some progress on the PC side of the cabinet this weekend.
I got MAME & MaLa installed and working. I created a custom desktop for the PC that ties in with the existing MaLa layout.
Using the same artwork I created my custom "Now Loading" screen. Really happy with the artwork I've done so far.
I made a few adjustments also as I had messed up and created a vertical window for the snap, I corrected this and made it horizontal.
I'll post all the artwork and layout should anyone want it.
I used Uncle T's awesome MaLa guide to install everything.
I made some amendments, only using emulators that had light gun games.
I also added a Play Station & Sega Saturn emulator.
Took me a lil while to get some of the required files, like DLL files and what not.
But now everything is installed and ready for tweaking. Other than finding some games that I
have not yet obtained I think I've got pretty much every base covered.
I'm hoping this week I can get the rest of my snap files, ROMs, and CHD files moved.
From that point I'll revert back to Uncle T's guide to ensure the emulators work via command line.
If all goes well I should be able to easily add them to MaLa.
Seeing as I used all the same emulators Uncle T did I'm hoping I have no problems.
I'm thinking (as they are not on the guide) that I might have some issue with the Saturn & PS1.
A buddy of mine has some extra RAM for me which I think will be a huge plus. I also went through my parts stash and I do have an extra videocard with S-Video out. However I might see if I can find something locally on Kijiji better suited.
mike boss:
Here is my artwork.
I'm hoping to NOT make additional layouts for each of the consoles emulated.
It's going to be too much work and even if I did they would just be slight variants of what I've already done.
This could change as I get further along, but for now that is the plan.
Shoot-em-up Multicade is the desktop image I'm using
Now loading is the custom load screen in MaLa
Two options of the main layout in MaLa, I'm going with the image that features the "use up/down to select game" and "press p1 to start" above the games list.
The other image has it above the snaps, but I don't think it makes sense.
mike boss:
Making some progress on this project.
Getting the PC fully configured has proven to be a real challenge.
TONS OF WORK !
For now I've got my layout working the way I want it.
Now its just a matter of getting all the emulators to work !
Here is a lil video of the menu.
BadMouth:
A little off topic, but since you've made a light gun list for each emulator.......
Are there any decent console light gun games that weren't just a ports of arcade games?
mike boss:
I think many of the games are indeed duplicates. The reason for the multi system set up was to perhaps find an emulator with better support of an individual game. For example I was told in MAME some games like House Of The Dead wont play correctly. However in M2 they play flawless. So adding M2 gives you the ability to play perhaps one of the best known gun games. Visually (and keep in mind I do plan on selling this cabinet) it makes for what reads like a more impressive cabinet. Also should a buyer want to add additional controls entire ROM sets are on the computer.
I've always sorta been a media wh0re of sorts. And even on my "altered" XBOX consoles I "HAD TO" have every emulator I could with every ROM I could. Something very cool (to me anyway) about having the ability to play one of your old time favorites regardless of what it is or what system its on.
PROJECT UPDATE :
Cabinet is cosmetically about done. Needs a good cleaning & the coin door needs a coat or two of black paint.
I have no decided yet on weather or not I want to go with side art.
26" Samsung TV has been purchased, tested, and working great. It's a widescreen LCD.
PC needs a new video card, which I have. It will also need more RAM which I am yet to get.
As far as the PC goes I've done the following :
MAME - working perfect.
NES - working perfect, solved my ESCAPE issue
SNES - working perfect
SEGA MASTER SYSTEM - working perfect, resolved my ESCAPE issue + full screen issue
SEGA 32X,GENESIS - not loading games
PLAYSTATION - not loading games
M2 - working outside of MaLa - needs an upgraded video card. In MaLa the games wont load
DREAMCAST (Chankast) - this is going to be my tuffest challenges. Gotta figure out the mounting of images.
