Author Topic: Coin Return Modification to Coin 1/2  (Read 2742 times)
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« on: January 01, 2011, 04:55:28 pm »
Currently on my existing arcade cabinet which has 2 player control panel.  The COIN 1 & COIN 2 buttons are located where one would use the pinball flippers buttons at.  I like this design very much but on my new arcade cabinet that Im building Im thinking about doing something new with the 1 & 2 coin buttons.
You know how on a coin door if you press the coin return button and the change spits out ..but on my setup I would like it to simulate Coin 1 & Coin 2 buttons....somehow/someway mount a microswitch(leaf?) up to the coin return button.
Just wondering if anyone has done this or not or even if its possible...any faqs on it?
Thank you all
Sav
abispac
  • Last login:February 20, 2026, 01:41:51 am
Re: Coin Return Modification to Coin 1/2
« Reply #1 on: January 01, 2011, 11:07:28 pm »
never done'it but its a great idea, i will implement that on my mini cocktail, it would make it look alot better, thanks for the idea .  :cheers:
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: January 02, 2011, 01:50:08 am »
Do a search. It's been done a lot.
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: January 02, 2011, 05:26:47 am »
That's how I wired mine. My coin door works with quarters or I can press the coin return button to "add credits".
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« Reply #4 on: January 02, 2011, 11:04:30 am »
I did something similar, but I was able to do mine with a standard microswitch without the lever. I still have my coin slot switches wired to '5' and '6' on my minipac, but I tapped into the p2 wiring on one of mine and epoxied a cherry switch on the side of my coin mech. Pressing the reject button in actuates the switch. I wired it as 'normally open' and when the lever lowers on the coin reject, the switch closes, registering a credit.
A small vid:
I still have to go back and wire one for the P1 credits on '5' too, because some games in MAME don't register a credit on '6.'
« Last Edit: January 02, 2011, 11:06:35 am by smalltownguy »
