Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
dmarcum99:
I put back in my 4350 using dvi via dvi/vga adapter. I plugged in the commands you requested and here's the output....trying the one command "find /sys/devices/pci0000\:01/ -iname card\*-\* did not yield any results.
arcade@GroovyArcade ~ $ lspci -v|grep VGA Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64
01:00.0 VGA compatible controller: ATI Technologies Inc RV710 [Radeon HD 4350] (prog-if 00 [VGA controller])
arcade@GroovyArcade ~ $ find /sys/devices/pci0000\:00/ -iname card\*-\*
/sys/devices/pci0000:00/0000:00:02.0/0000:01:00.0/drm/card0/card0-HDMI-A-1
/sys/devices/pci0000:00/0000:00:02.0/0000:01:00.0/drm/card0/card0-VGA-1
/sys/devices/pci0000:00/0000:00:02.0/0000:01:00.0/drm/card0/card0-DVI-I-1
arcade@GroovyArcade ~ $ /usr/local/bin/xorg.sh
mount: only root can do that
# Unsupported video card!!!
bitbytebit:
--- Quote from: dmarcum99 on March 31, 2011, 01:33:57 am ---I put back in my 4350 using dvi via dvi/vga adapter. I plugged in the commands you requested and here's the output....trying the one command "find /sys/devices/pci0000\:01/ -iname card\*-\* did not yield any results.
Interesting, whats the entire output of lspci -v? That first part, the Flags... line, seems like it might be the issue.
Update: Here's a new xorg.sh script, unzip and put it on the system (you'll need to be root, run `sudo -s` first, also that'll help execute xorg.sh better too), place it under /usr/local/bin/xorg.sh. Then rerun the video config setup, see if that helps.
dmarcum99:
I reran the lspci -v|grep VGA command, and there was no additional info. I was worried that I left something out, but after running it several times it looks like I copied all the info on the output.
I reran the /usr/local/bin/xorg.sh with the new file you provided and it had a lot of info this time....here's the output:
arcade@GroovyArcade ~ $ sudo -s /usr/local/bin/xorg.sh
# Config for generic Monitor and ati Video Card
Section "Monitor"
Identifier "DVI-0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 15-50
VertRefresh 40-80
Option "DPMS" "False"
Option "DefaultModes" "False"
UseModes "ArcadeModes"
EndSection
Section "Device"
Identifier "Card0"
BoardName "Unknown"
Driver "ati"
BusID "PCI:01:00:0"
Option "ModeDebug" "true"
Option "monitor-DVI-0" "DVI-0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "DVI-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Modes"
Identifier "ArcadeModes"
# 648x480@60.00 15.7500Khz
ModeLine "648x480x60.00" 13.230000 648 672 736 840 480 484 490 525 -HSync -VSync interlace
EndSection
bitbytebit:
--- Quote from: dmarcum99 on March 31, 2011, 02:09:50 am ---I reran the lspci -v|grep VGA command, and there was no additional info. I was worried that I left something out, but after running it several times it looks like I copied all the info on the output.
Section "Monitor"
Identifier "DVI-0"
ModelName "Unknown"
HorizSync 15-50
VertRefresh 40-80
EndSection
Section "Device"
Identifier "Card0"
BoardName "Unknown"
Driver "ati"
BusID "PCI:01:00:0"
EndSection
Section "Screen"
Device "Card0"
Monitor "DVI-0"
DefaultDepth 24
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Modes"
EndSection
Yep that should do it I think, put that under /usr/local/bin/xorg.sh and rerun the gasetup, I am guessing that may make things a bit better.
dmarcum99:
I certainly appreciate all the help. :notworthy: Donation worthy without question. :notworthy:
Running these two games (mace & wg3dh), they're still running too fast. A few post ago you asked me to ssh in and get an output while the game is running. I did this again since I got a new xorg.sh file. I also attached the groovymame verbose info. This info is from wg3dh...and I had a ini set to 640x480x32@57.00
**note** as soon as I "tab" into the mame control panel, the game slows down....I almost dare to say that it slows to the correct speed.
