Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
NightSprinter:
Still having issues, but would you know if that video addition to the kernel line would work in GRUB2 as well?
Ansa89:
It should work also on grub2, since it is a kernel parameter and not a grub related thing.
NightSprinter:
Yup, it finally worked (though I had to save the default kernel source's config file and load it into the 3.8 sources so it could finally boot). I've got it booting on Fedora 18 with a 720x480 15KHz console. Once I get home tonight from work, I just need to figure out the "bad parameter" error I'm getting again from switchres. Another semi-related issue is with certain native/wine games locking up the display. I might have Calamity look into that as well, as it happened with modelines generated from SwitchRes.
Ansa89:
Update 15KHz patches for linux 3.9.
NightSprinter:
Thanks greatly for the 3.9 patch. Not only did it patch correctly on the first attempt, but it boots wonderfully with a 15KHz console and native linux games running at proper arcade resolutions. I'm curious, though, what are your thoughts on the new Intel HD5000 graphics series for GroovyUME and native linux gaming on arcade monitors?
