Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
bitbytebit:
Diffs are up for mame 0143, will get the mame ebuild and CD ISO images updated soon hopefully, probably next few days.
ves:
Hello bitbytebit , this morning I started to update the diff for the new version but have been faster than expected ;D, even thought these out of service, so much better.
You will not include the patch wiimote? and Openppjoy with applications that you said they were for the new livecd?
Thank you.
dmarcum99:
I am intrigued with the wiimote thing as well. A new gun that has a wiimote built-in the housing is available now. It's called Scorpion VII. I am dying to hear if this can work with groovymame.
http://superufo.com/product_html/Nintendo_Wii_Wii_Scorpion_Vii.html
ves:
Hello updated the patch to use the wiimote with the new version of groovymame 0143, you can also patch with the original mame 0143, might give you some offset errors but they patched it and it works.
Greetings.
bitbytebit:
--- Quote from: ves on July 01, 2011, 07:15:37 am ---Hello updated the patch to use the wiimote with the new version of groovymame 0143, you can also patch with the original mame 0143, might give you some offset errors but they patched it and it works.
Greetings.
Cool I will check this out, might have it as a separate patch along side the groovymame one, so things are easier to keep updated in the future with mame changes.
Hopefully I get to the ISO in the next week, although I'm sort of waiting on Linux kernel 3.0 to come out first since I'd like to update it. I have the newer kernel patch modified to work (3.0-rc5), but haven't tested it yet to make sure it's good. Then I'll wait till 3.0 comes out probably, so can do the big upload all at the same time.
