Main > Project Announcements
Wii / Kinetic / PS Move Cabinet - Project Interaktiv
Pages: << < (2/3) > >>
SpaceHedgehog:
I seem to be racing through the early stages ... there's no substitue for having good plans in place  :laugh2:
Anyway, All except the top shelf has now been glued and screwed in place. Here's a pic with the legs in position:
I'll be making a mount for the tv that will sit in the empty cavities/tubes.
Edit:
To give you some idea of the scale, the legs are 70cm hight and the cabinet around 64cm wide.
SpaceHedgehog:
Each leg is attached with 5 screws so it should be pretty secure, certainly feels it.
jimmy2x2x:
Looking good, very fast progress!
Are you using a table saw to cut the mdf?
SpaceHedgehog:
Thanks! I cut the MDF with a circular saw, sadly I dont have a table saw  :(
Here's stage 1 of the VESA mount. This thing needs to be pretty tough to hold the tv in place. The 'prongs' will fit down the cavities in the table legs. I will attach another piece with the correctly spaced holes for the tv to it.
Edit:
A couple of pics with it in place:
SpaceHedgehog:
Here's a pic of the TV I'll be using:
And the second part of the Vesa Mount:
Go to full version
