Main > Project Announcements
22" Touchscreen inwall Jukebox
struisje:
I will try to fit the whole screen in the wall without removing the case.
But first things first.
Today I will be running some cable from the house to the stables (the stables have been converted into a bar).
Currently I have a 1.5mm Power cable going from the house to the stables. I'm going to change it for something stronger. Now I can hook up about 3600 Watt to it. But when I'm using the waterboiler (2000W) and the fridges and the lighting, it's just not strong enough.
And adding a computer to it won't help much.
Now that we're digging anyway I'm gonna put some coax and some cat6 ethernet cable down as well.
Distance to cover : about 20m (about 22 yards)
Temperature this afternoon: 33°C (about 91°F) :-[
Pictures to follow.
struisje:
We've done some work the last few days.
The distance we had to dig was 45 metres.
I put in a new power cable, grounding, 2 cat6 ethernet cables and a coax cable.
We cut the hole in the wall and placed in the screen.
We still have to make a cabinet for the pc and then mount the speakers in the room.
The 22" touchscreen built in the wall of the bar. We still have to make a frame to hide all the holes. Only the visible part of the screen will show then. The case will be hidden.
Close up of the screen
Picture from the back. For now I put two speakers in there, In the future I will hang them on the walls
Picture from the back with the PC and subwoofer. We will make a custom cabinet for the PC, we're doing some testing with the audio system, but I think I will buy new, more powerful speakers.
Close up of how we keep the screen in place.
javeryh:
Wow - cool. How did you cut the hole in the wall?
struisje:
First I drew the lines and made sure it was all level.
Then I used a tool like this (I don't know what the word is in english but in dutch it's 'slijpschijf')
I drilled a hole through the wall in every corner so I knew where to cut on the other side of the wall.
Then i used one of these to remove the remaining concrete and make it even.
TEKNYNE:
Top tool is an angle grinder and bottom is a roto-hammer or chisel hammer or combination cant really tell.
