Main > Project Announcements
Dedicated Mortal Kombat 9
Pages: << < (4/7) > >>
childsremix:
This is an awesome idea and depending on the actual layout of the buttons I may end up sticking mk9 in my multi jamma MK machine myself!  Have they at all talked about the layout of the buttons will it be the same six buttons or are they planning on looking at this from a console perspective and using all 8 buttons?
amendonz:
Cool stuff. I'l be watching with interest. Looking at building a mvc3 machine similar to this.
saloonstudios:
--- Quote from: tcleary on June 22, 2010, 10:10:32 pm ---check out this footage of the new mortal kombat if you haven't seen it, it's looking good.
http://e3.gamespot.com/video/6266626/
I had no idea what I was missing. This potentially changes all of my plans as well. Thanks and can't wait to see what you come up with-
Although my cab is going to have an SD CRT, so that could feel like a waste of all the new HD gfx that this game will have...
tcleary:
time to get back on this.  I traded my war gods cab for a painted over MK2 cab so I have a blank slate to work with.  I saw some fight sticks that are coming out with the game and they have the old MK layout with the run button, so button layout will be easy enough, now I just need art.
I also did a ton of research trying to find the best lcd for an arcade cab and the best I could do was the dell u2311h.  viewing angle is the main problem, if you want the monitor flush with the cabinet you will be looking at it at an angle most of the time.  I had a standard cheapo TN panel in the cab and the viewing angle was garbage, the top of the screen would be unviewable in dark scenes in super meat boy.
then I tried rotating the cheap monitor and the viewing angle playing a vertical game (ikaruga in this case) was awful, you had to be right in front of it at the perfect angle, which would be impossible playing two players.  the u2311h on the other hand looks pretty damn good at any angle, even when set to vertical.  the only downside is it is 8ms vs 2ms of the other panel, but after comparing back to back I didn't notice the slower response rate enough to count, but the viewing angle and overall image quality was very noticeable.  the u2311h is 1080p, so perfect for an xbox 360.  you could use a 1920X1200 monitor, but the image will be stretched, which annoyed me when I tried it, I like having the proper aspect ratio.
so it's the monitor I recommend if you are planning on making an xbox 360 cab.
on to mortal kombat 9
my main issues with this cab are the art all around, and the monitor because I like being able to rotate it.  right now I have the monitor just kind of sitting in the cabinet and it's kind of ghetto.  the best solution would be some sort of mount that would allow you to pull the monitor out, rotate it, then set it back in place, but I don't know if that exists.  If I get sick of ikaruga I may just mount it horizontal and be done with it.
so next up that can be worked on is the controls.  I'm looking around for cheap fight sticks I can hack up.
Gatsu:
Are you still going to make this a dedicated MK9 cab?
If so I'd drop the rotating monitor all together and just get a regular tv or non hidef arcade monitor.
just my thoughts...
Go to full version
