Main > Project Announcements
Dedicated Mortal Kombat 9
Pages: << < (3/7) > >>
tcleary:
got the 24" lcd and mounted it with the vesa screw holes to the 3/4 board I mounted on the monitor brackets, worked out ok.
highlife:
Have you already ideas for the side art? I'm thinking a long time to make a custom MK side art but I'm waiting for HQ pictures from MK 9 however MK 9 not playable is on my cab. I've found some picuteres and created my own Marquee maybe you like it.
I hope there will be a good Side Art.
BurgerKingDiamond:
I like your idea for a MK9 cab, but I think it would look a thousand times better with a 4:3 monitor. I never like the way it looks to have a widescreen monitor in a cab that wasn't made for it. It's all out of proportion and there is so much empty space. Although if you chose 4:3 big enough to really fill out that cabinet you would probably have to sacrifice HD output, and go for an older CRT TV, because everything seems to be widescreen nowadays. I don't think you can find many 27" 4:3 LCD monitors...
tcleary:
i like that marquee but it needs to say "MK9" or something like that
I have a MK cab with a 27" 4:3 tube and it's ok,  i had the x360 in there, but next gen games simply look better on the 24" widescreen 1080p lcd.  yeah it does look weird in there but after a while I don't really think about it.  my arcade is not a beauty contest so it works for me.
severdhed:
--- Quote from: highlife on July 22, 2010, 02:18:52 pm ---Have you already ideas for the side art? I'm thinking a long time to make a custom MK side art but I'm waiting for HQ pictures from MK 9 however MK 9 not playable is on my cab. I've found some picuteres and created my own Marquee maybe you like it.
perhaps "ARKADE" would have fit better with the theme
Go to full version
