Main > Project Announcements
[37"/24"/15"] - '77 Bally Power Play "Donor" Visual Pinball Build
Pages: << < (8/13) > >>
njay:
mwong
open the table scripts and look for some line that says if vpmnudge key is blabla use key45 , comment the line out usually JP tables and some others use hardcodes lines for keys for nudging
did you install the mercury yet
mwong168:
The mercury switches have been installed in my cab and appear to work in Windows when I initially tested out all my inputs on my netbook but haven't had a chance to test it out in Visual Pinball yet but they seemed to respond well when I nudged them.  I will get to that a bit later, right now I am trying to resolve some issues mapping my keys in Xpadder.  I have mapped all the visual pinball default keys and they all works fine.  For example the left and right shift keys work 100% in Visual Pinball but inside Hyperpin it only seems to recognize the left flipper button and when I press the right flipper it is as if I am hitting the ESC key instead even though it is mapped to the right shift key.  That was my tilt problem before actually cause initially I had remapped the right shift key to "." but haven't figured out how to change the key inside Hyperpin.  What I find odd is that either all keys should work properly or none at all.  I'll figure it out and will definately share in case anyone else used the LED+GPWiz or GPWiz which are both USB gamepad encoders.
HaRuMaN:
Is it me, or is the LCD lower on the left edge than it is on the right edge?
mwong168:
--- Quote from: HarumaN on May 25, 2010, 11:24:48 am ---Is it me, or is the LCD lower on the left edge than it is on the right edge?
The initial pics I took of the Simpsons Pinball Party was when I just threw everything inside to try everything out and the playfield was lower on the left side.  In my later pics with The Twilight Zone I have shimmed it so it is level using the existing play field mounts.  It's sort of ghetto but the only thing I could find that was just right was a paint stir stick  :lol  I will fix this later but right now I am just trying to figure out my HyperPin issues with the button mapping in Xpadder.  Going to dress the cabinet up in some nice artwork too once I come up with a theme.
njay:
check your hyperpin ini file for the key settings
its called settings.ini
Go to full version
