Author Topic: Jamma wiring questions....  (Read 1118 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: July 16, 2009, 07:55:07 pm »
I'm looking to possibly re-wire a japanese cabinet for Jamma. Now, I was just wondering whether this would be a simple enough task and what I would required to do in order to do this. Say, I had a 29" monitor that worked and a pair of speakers from the original cab - what else would I need to get it up and running to play jamma? I know, of course, you'd need a jamma harness and a PSU - would the latter need to be a certain type or could any arcade PSU be used? Or would it be a case of having the same output as the original PSU? Also, would you need an audio amp of some type? If so, could this be any arcade audio amp, or would it have to be specific to the cabinet? Lastly, with the jamma harness, would all the connections be fairly straight forward to get the bare cabinet up and running (monitor, speakers, controls)?
Sorry this are such niave questions but until the best way to learn things is by doing them (and asking people who know about them too! ;D)
mj147
  • Last login:May 19, 2026, 07:47:25 pm
Re: Jamma wiring questions....
« Reply #1 on: July 16, 2009, 10:38:01 pm »
For a guide visit Bob Robert's How too..Jamma
Ive rewired  a few Jamma cabs before and can seem overwhelming at first but just group sections off and take your time.  its even easier if you get a harness with pinouts prelabled :)
The audio amps are handles by the actual game  board so no amp is required separately.
On the psu, some games use puter psu so its possible, its just easier and usually cheaper getting an arcade psu.
Hopped I helped out a bit  ;)
mj147
slapaham
« Reply #2 on: July 17, 2009, 05:17:41 am »
Hi mate
Thanks for the help... appreciate it! :cheers:
